node-red-contrib-remootio 1.0.12
Node-RED Remootio Integration
npm install node-red-contrib-remootio
node-red-remootio
Node-RED nodes to talk to Remootio using the Remootio Websockets API .
    npm install node-red-remootio
Provides three nodes - one to listen to events, one to send actions and a global configuration nodes credentials: remootio for Websocket credentials
credentials: remootio is a global configuration node that contains the IP Address, API Secret Key and API Auth Key required to connect to your Remootio Device.
See Enabling the API in the Remootio documentation.
events: remootio
events: remootio node, can be used to listen for Remootio events
Inputs
Takes a credentials: remootio input for authentication and connectivity to your Remootio device.
Outputs
When returning events it sets the msg.payload.event to the remootio event, a full list is documented by Remootio.
Sets msg.payload.state to the state of the event open or closed
Sets msg.payload.type to the type of the event :
  • StateChange
  • RelayTrigger
  • SecondaryRelayTrigger
  • OutputHeldActive
  • SecondaryOutputHeldActive
  • Connected
  • LeftOpen
  • KeyManagement
  • Restart
  • ManualButtonPushed
  • ManualButtonEnabled
  • ManualButtonDisabled
  • DoorbellPushed
  • DoorbellEnabled
  • SensorEnabled
  • SensorFlipped
  • SensorDisabled
switch: remootio
switch: remootio node, can be used to send command to your Remootio device
inputs
Takes a command from a dropdown, available commands are :
  • sendPing
  • sendHello
  • sendQuery
  • sendTrigger
  • sendOpen
  • sendClose
  • sendRestart
Support
If you've found this useful and want to support my sleepless nights:
coffee
Version: 1.0.12
Updated 4 years, 3 months ago
23 in the last week
  • credentials: remootio
  • events: remootio
  • switch: remootio
  • remootio
  • home automation
  • home assistant
