node-red-contrib-relaycontrol 0.0.1
Control relay boards
npm install node-red-contrib-relaycontrol
A module that allows controlling different relay boards from Node-RED.
Tested with:
Flow
A typical flow consists of a node injecting either a 0 / 1 or true / false into the node. The node will respond to switch the attached relay. Flow
Board configuration
Each board in the network needs to be configured first. Depending on the manufacturer, you may need to fill out either only the IP address/hostname or some additional fields.
Port configuration
Once the board has been configured and selected, the port for the relay needs to be added.
Version: 0.0.1
Updated 3 years, 2 months ago
6 in the last week
  • config-relay-board
  • relay board
  • devantech
  • teracom
  • shelly
  • relay
  • victron
