node-red-contrib-relay-no-nc 1.0.1
A Node-RED node that mimics latched NO NC relay logic.
npm install node-red-contrib-relay-no-nc
NoNC Relay Node for Node-RED
This module provides a simple NO (Normally Open) and NC (Normally Close) relay node for Node-RED. It allows you to control the flow of messages based on an "enable" or "disable" signal received on a specific topic.
  1. Download this module or clone the repository.
  2. In your Node-RED user directory, run:
npm install .
or install it online as
  1. Add a "relay-no" or "relay-nc" node to your flow.
  2. Configure the following properties:
    • name: A name for the node (optional).
  3. Use "enable" and "disable" messages on the specified topic to control the node's behavior:
    • Topic: Set the topic to enable or disable the node.
    • Enable: Send a message with boolean payload: true on the topic to enable the node.
    • Disable: Send a message with boolean payload: false on the topic to disable the node.
  4. Connect the output of the node to other nodes in your flow.
Example:
[{"id":"cac80ffbe4fd7cdf","type":"tab","label":"NoNc relay","disabled":false,"info":"","env":[]},{"id":"c62efe0fc73eedd5","type":"relay-nc","z":"cac80ffbe4fd7cdf","name":"","x":580,"y":120,"wires":[["fc4b91857193f24b"]],"icon":"font-awesome/fa-toggle-on"},{"id":"6ba8304f67a71aea","type":"relay-no","z":"cac80ffbe4fd7cdf","name":"","x":580,"y":340,"wires":[["bd01d2118d3bc903"]],"icon":"font-awesome/fa-toggle-off"},{"id":"9d3709f217dd31b1","type":"inject","z":"cac80ffbe4fd7cdf","name":"start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":90,"y":120,"wires":[["06acb202d410bc41"]]},{"id":"06acb202d410bc41","type":"change","z":"cac80ffbe4fd7cdf","name":"set msg.topic value to enable","rules":[{"t":"set","p":"topic","pt":"msg","to":"enable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":120,"wires":[["c62efe0fc73eedd5"]]},{"id":"5ad74b28eb0a9a42","type":"inject","z":"cac80ffbe4fd7cdf","name":"stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":90,"y":180,"wires":[["de83210adc71f7ec"]]},{"id":"de83210adc71f7ec","type":"change","z":"cac80ffbe4fd7cdf","name":"set msg.topic to value disable","rules":[{"t":"set","p":"topic","pt":"msg","to":"disable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":180,"wires":[["c62efe0fc73eedd5"]]},{"id":"a81dccfd5da6d6dd","type":"inject","z":"cac80ffbe4fd7cdf","name":"start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":90,"y":320,"wires":[["e317d76da1a30f77"]]},{"id":"e317d76da1a30f77","type":"change","z":"cac80ffbe4fd7cdf","name":"set msg.topic value to enable","rules":[{"t":"set","p":"topic","pt":"msg","to":"enable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":320,"wires":[["6ba8304f67a71aea"]]},{"id":"f76a355abff041e4","type":"inject","z":"cac80ffbe4fd7cdf","name":"stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":90,"y":380,"wires":[["f231bb515d55e45d"]]},{"id":"f231bb515d55e45d","type":"change","z":"cac80ffbe4fd7cdf","name":"set msg.topic to value disable","rules":[{"t":"set","p":"topic","pt":"msg","to":"disable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":380,"wires":[["6ba8304f67a71aea"]]},{"id":"f9dc57b2a3f58c67","type":"inject","z":"cac80ffbe4fd7cdf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":570,"y":40,"wires":[["c62efe0fc73eedd5"]]},{"id":"fc4b91857193f24b","type":"add","z":"cac80ffbe4fd7cdf","name":"","topic":"","x":830,"y":120,"wires":[["717d71837bc35320"]]},{"id":"717d71837bc35320","type":"debug","z":"cac80ffbe4fd7cdf","name":"Output","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1030,"y":120,"wires":[]},{"id":"02866db2697ce95c","type":"inject","z":"cac80ffbe4fd7cdf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":570,"y":260,"wires":[["6ba8304f67a71aea"]]},{"id":"bd01d2118d3bc903","type":"add","z":"cac80ffbe4fd7cdf","name":"","topic":"","x":830,"y":340,"wires":[["ab118dad172ca56a"]]},{"id":"ab118dad172ca56a","type":"debug","z":"cac80ffbe4fd7cdf","name":"Output","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1030,"y":340,"wires":[]},{"id":"a2413759ab4504eb","type":"comment","z":"cac80ffbe4fd7cdf","name":"NoNc Relay ","info":"","x":110,"y":40,"wires":[]}]
This example demonstrates No Nc functionality - The default status of NO node is Normally Open, ie it blocks all messages passing through it unless explicitly enabled and NC node is Normally Closed, ie it allows all messages to pass through it unless its explicitly set to disable.
Notes
  • The node checks the message topic and payload to determine whether to enable or disable message forwarding.
  • The node's status reflects its current state (enabled/disabled).
  • This node operates as latched relay, ie it maintains its current state unless explicitely changed by user
Author
  • Harshad Joshi @ Bufferstack.IO Analytics Technology LLP, Pune
Contributing
We welcome contributions to this project. Feel free to submit pull requests with improvements or bug fixes.
Version: 1.0.1
Updated 2 years, 10 months ago
License: GPL-3.0
Rating: 5.0 4
9 in the last week
  • relay-no
  • relay-nc
  • relay
  • logic
  • boolean
  • input
  • output
