node-red-contrib-redplc-piface 1.0.11
Node-Red node for PiFace Digital Module
Node Features
- 8 x Digital Outputs with 2 x Relays
- 8 x Digital Inputs with 4 tactile Switches
- 8 x Leds for Digital Inputs
- Four selectable Module Address
For using with Ladder-Logic install redPlc nodes
For using with other nodes, install module nodes
Install with Node-Red Palette Manager or npm command:
npm install node-red-contrib-redplc-piface
Update is triggered by redPlc cpu node
or module-update node
This node reads/writes from/to Node-Red global variables
This node works only on Raspberry Pi with Raspberry Pi OS
Enable SPI with raspi-config
I/O Mapping
Digital Input (Variable I):
Pin | Bit | Function |
I0 | 0 | Input 0, Switch S0 |
I1 | 1 | Input 1, Switch S1 |
I2 | 2 | Input 2, Switch S2 |
I3 | 3 | Input 3, Switch S3 |
I4 | 4 | Input 4 |
I5 | 5 | Input 5 |
I6 | 6 | Input 6 |
I7 | 7 | Input 7 |
Digital Output (Variable Q):
O0 | 0 | Output 0, Relay 0 |
O1 | 1 | Output 1, Relay 1 |
O2 | 2 | Output 2 |
O3 | 3 | Output 3 |
O4 | 4 | Output 4 |
O5 | 5 | Output 5 |
O6 | 6 | Output 6 |
O7 | 7 | Output 7 |
Donate
If you like my work please support it with donate:
