node-red-contrib-realix-erc 1.0.4
Realix ERC integration nodes for Node-RED (escape room control via MQTT)
npm install node-red-contrib-realix-erc
Node-RED integration for the Realix Escape Room Controller (ERC)
This Node-RED package provides full MQTT-based integration with the
Realix Escape Room Controller, enabling you to automate puzzles,
control physical devices, play media, and build complete escape room
logic flows using the quick and visual environment of Node-RED.
With these nodes you can interact with both SBUS hardware devices
and software objects defined in the Realix Designer.
SBUS Hardware Devices
SBUS is Realix’s escape-room hardware bus carrying power + data
over a single daisy-chain cable.
These nodes are used to interface with SBUS channels:
Node Object Type Description
Output Digital Output Activate, deactivate, pulse, pulse-train
Actuator Motor/Servo/Linear Actuator Set percentage or transient movement
Input Digital Input Receive numeric input values
Sensor Analog Sensor Receive sensor values
RFID Reader RFID Reader Receive tag UIDs
SBUS devices are auto-discovered by the Realix Server and become
instantly available in Node-RED.
Other Devices
Next to SBUS, Realix-ERC supports DMX, Philips Hue and MediaPlayers for audio, video and several view types.
These nodes are used to control the objects in other devices.
Light DMX or Hue Light Set color, temperature, brightness, fade
Audio Player Audio Player Play, stop, fade audio
Video Player Video Player Play, stop, fade video
Text Viewer Viewer Display text
Image Viewer Viewer Display images
Custom Viewer Viewer Custom HTML views
Time Viewer Viewer Display escape count down time
These run inside the Realix Server and are controlled via MQTT commands.
SBUS β€” Power & Data Combined
SBUS dramatically reduces cabling in escape rooms:
  • Power + communication in one cable
  • Daisy-chain topology
  • Auto-discovery of devices
  • Channel-based hardware addressing
  • Very robust for escape-room environments
Outputs, actuators, inputs, and sensors all map directly to SBUS channels.
Realix Server & Designer to support SBUS
To use this package, download:
πŸ‘‰ https://realix-erc.com/downloads/
Install both:
  • Realix Server (runtime engine)
  • Realix Designer (project designing environment)
Setup Steps
  1. Create a new project in Realix Designer
  2. Choose MQTT-based project type
  3. Install the SBUS-Box hardware
  4. Add SBUS-Box Device in Room Setup
  5. SBUS devices will auto-discover
  6. Assign objects to SBUS channels
  7. Create software devices (audio/video/viewers/etc.) as needed
All objects become accessible from Node-RED automatically.
Installation on Node-RED
Install from Node-RED Editor
  1. Open Node-RED
  2. Go to Menu β†’ Manage palette β†’ Install
  3. Search for:
  1. Click Install
Install via npm
Or install inside your Node-RED user directory:
After installation, all nodes appear under the realix category.
Documentation
Full documentation and support resources:
Support
For assistance, contact:
πŸ“§ [email protected]
This package is licensed under the MIT License.
Version: 1.0.4
Updated 8 months, 3 weeks ago
3 in the last week
  • erc-config
  • erc-output
  • erc-actuator
  • erc-light
  • erc-audioplayer
  • erc-audioinput
  • erc-videoplayer
  • erc-imageviewer
  • erc-textviewer
  • erc-customviewer
  • erc-timeviewer
  • erc-input
  • erc-sensor
  • erc-rfidreader
  • erc-trigger
  • erc-lock
  • erc-switch
  • erc-device
  • erc-system
  • erc-request
  • node-redscape
  • realix-erc
  • escape-room
  • mqtt
