node-red-contrib-re-postgres 0.3.4
A Node-RED node to query PostgreSql
npm install node-red-contrib-re-postgres
A Node-RED node to query PostgreSQL based on original node by Kris Daniels. This node clearly replaces original node to be compatible with latest Node-red versions.
The node-red postgres node uses a template node to set the query and uses msg.queryParameters as params for the query.
Each property in msg.queryParameters can be used as $propertyName in the query, see the 'setup params' and 'format query' node in the example.
The msg it then passed to the postgres node.
If you want the output of the query, check the 'Receive output' box in the postgres node.
If you want the output of the query been sent by row, check the 'One message per row' box in the postgres node.
The result of the query is then set on the msg.payload property which can be sent to a http node.
Changes
  • Some compatibility fixes
Version: 0.3.4
Updated 4 years, 5 months ago
Rating: 2.8 8
268 in the last week
  • postgresdb
  • postgres
  • postgres
  • postgresql
