node-red-contrib-re-modbus-tcp-ip 1.2.0
Connects to a modbus slave and performs modbus read operations via TCP /IP
npm install node-red-contrib-re-modbus-tcp-ip
Forked from https://github.com/balaji8385/node-red-contrib-modbus-tcp-ip
Version 1.2.0
  • Modified error log handling
  • Empty port can be saved without error
  • Exception can now be cought from catch node
  • Added number of retries and retry period in ms
  • All parameters can be send as input in the payload
Internal code rework:
  • The promise is used to control flow in case a connection could not be established
Node-RED Modbus TCP Flexi Reader
Connects to a modbus slave and performs modbus read operations via TCP/IP.
Getting Started
Install the module via npm or directly via node-red. The module will be located in the function block. See help for an example.
Flow
Flow
Editing Connection
Edit Connection
Injecting Payload
Input Payload
Additional Payload Options
You can also send the modbus ip and port along with payload instead of giving it at the input of node. The values inside the configuration dialog will be used with higher priority. So you have to empty them if you want to send the parameters as payload. Eg: {
"unitid":5,
"functioncode":3,
"address":3000,
"quantity":100,
"modbus_ip":"192.168.10.31", "modbus_port": 3666, "timeout": 100, "retries": 0, "retry": 100, "logerror": true }
Authors
Makes use of:
  • modbus-stream (is included directly to avoid build problems with serial drivers)
  • modbus-pdu
This project is licensed under the MIT License - see the LICENSE.md file for details
Version: 1.2.0
Updated 5 years ago
Rating: 4.5 2
15 in the last week
  • modbus-get
