node-red-contrib-rbc 1.0.4
It is a node for node-red which sends data only if tehre is a defined change in the message. E.g. smaller, greater value.
node-red-contrib-rbc (report-by-changes)
A Node-RED node that provides a function to report-by-change (RBC) capability.
The node blocks unless the incoming value changes in a defined mode.
npm i node-red-contrib-rbc
A simple node to provide report-by-change (RBC) - only passes on data if it has changed in defined way.
This works on a per msg.topic
basis. This means that a single rbc node can
handle multiple topics at the same time.
Greater Than mode
The node doesn't send any output until the msg.payload
is greater to the previous one.
Works only on numbers.
Less Than mode
is lesser to the previous one.
Output modes
You can choose, if you want to send the current msg-Object, the previos one or the first of this check one.
