node-red-contrib-raspi5-stepper 1.0.0
Raspberry Pi 5 28BYJ-48 stepper motor with ULN2003 driver, pure JavaScript Node-RED node with selectable GPIOs, direction, steps or turns, half/full/wave step
npm install node-red-contrib-raspi5-stepper
28BYJ-48 stepper motor Node with ULN2003 driver board for Raspberry Pi 5 – pure JavaScript, no Python, no external daemon, no native addon.
Supports:
  • 4 GPIOs selectable (IN1..IN4) in the node
  • Requests by direction (left / right), steps or turns
  • Continuous run until stop
  • Half step, full step and wave drive
  • Steps per turn and step time (ms) configurable
  • Position counter, done / stopped output events
  • Dynamic wiring hints and speed display in the Node-RED editor
⚠️ Prerequisite: sysfs GPIO
This node talks directly to /sys/class/gpio (works on Raspberry Pi OS Bookworm / Trixie).
Check:
ls /sys/class/gpio
You should see:
export  gpiochip571  ...  unexport
On the Pi 5 the header GPIOs start at an offset (e.g. gpiochip571).
The node finds this offset automatically.
The user running Node-RED must be in the group gpio (see Test / Debug).
Wiring
The node editor shows dynamic wiring instructions for the selected GPIOs.
Default GPIOs (no conflict with SPI0, SPI1 or I2C):
ULN2003 Raspberry Pi 5
IN1 GPIO5 (Pin 29)
IN2 GPIO6 (Pin 31)
IN3 GPIO13 (Pin 33)
IN4 GPIO26 (Pin 37)
+ (5-12V) 5V (Pin 2 or 4) or external 5V supply
- GND (Pin 39)
  • Motor: 5-wire plug into the white socket of the ULN2003 board
  • ⚠️ Never connect the motor coils directly to the GPIOs
  • ⚠️ External supply → common GND with the Pi
  • One 28BYJ-48 (5V) draws ~240 mA
Via Node-RED Palette
Search for:
Manual install
sudo systemctl restart nodered
Node Configuration
Configured entirely inside the node:
  • IN1, IN2, IN3, IN4 (GPIO numbers, BCM)
  • Step mode:
    • half – smooth, 4096 steps per turn
    • full – more torque, 2048 steps per turn
    • wave – one coil, low power, 2048 steps per turn
  • Steps per turn
  • Step time (ms) – the editor shows the resulting speed (s per turn / rpm)
  • Default direction
  • Invert (swap left / right)
  • Release (coils off after each move: no heat, but no holding torque)
The 28BYJ-48 reaches ~15 rpm max: half step ≥ 1 ms, full step ≥ 2 ms.
Input
One request per message. Use direction and one of steps or turns.
The values can be in msg or in msg.payload.
Steps
msg.direction = "right"
msg.steps     = 512
Turns
msg.payload = { direction: "left", turns: 2 }
msg.payload = { turns: 0.25 }          // default direction
Continuous
msg.direction = "left"                 // only a direction
msg.payload   = "right"                // or as payload string
Runs until stop or the next request.
Commands
msg.payload = "stop"                   // stop (release if enabled)
msg.payload = "release"                // stop + all coils off
msg.payload = "zero"                   // position = 0
Notes
  • steps and turns in the same request → error
  • negative steps / turns → other direction
  • msg.payload = 200 (number) → 200 steps in the default direction
  • msg.stepMs → step time for this request only
  • a new request stops the running move (output stopped) and starts the new one
Output Events
Move finished
topic: "done"
payload.event: "done"
Move stopped / replaced
topic: "stopped"
payload.event: "stopped"
Payload
payload.direction:      "left" | "right"
payload.requestedSteps: <number> | null (continuous)
payload.steps:          <steps done>
payload.turns:          <turns done>
payload.position:       <total steps, right = +>
payload.positionTurns:  <total turns>
payload.stepMs:         <ms>
payload.ms:             <duration>
Safety
  • ❌ Motor never directly on GPIOs – always via ULN2003
  • ❌ The node refuses the same GPIO twice
  • ✅ Coils are switched off on deploy / stop of Node-RED
  • ✅ Editor warns if a GPIO belongs to SPI / I2C / UART
Test / Debug
Check permissions:
groups
# user must be in group: gpio
Add user if needed:
sudo usermod -aG gpio $USER
Re-login required.
Motor only vibrates / does not turn:
  • wrong IN order → check IN1..IN4 wiring
  • step time too short → increase Step time (ms)
  • weak power supply
Turns the wrong way → enable Invert.
MIT
Version: 1.0.0
Updated 3 weeks, 4 days ago
  • raspi5-stepper
  • node-red-contrib
  • raspberry-pi
  • raspberry-pi-5
  • stepper
  • stepper-motor
  • 28byj-48
  • uln2003
  • gpio
  • motor
