node-red-contrib-raspi5-rc522 1.1.6
Raspberry Pi 5 RC522 (MFRC522) pure JavaScript Node-RED node with SPI0/SPI1, UID/READ/WRITE and present/removed events
npm install node-red-contrib-raspi5-rc522
RC522 / MFRC522 RFID Node for Raspberry Pi 5 – pure JavaScript, no Python, no external daemon.
Supports:
  • SPI0 and SPI1 (bus/device selectable)
  • UID / READ / WRITE (MIFARE Classic)
  • Auto polling or trigger-by-message
  • Presence events: present / removed
  • Dynamic wiring hints in the Node-RED editor
⚠️ Prerequisite: SPI must be enabled
This node talks directly to /dev/spidev*.
If SPI is not enabled, the node cannot work.
Enable SPI0 (standard)
sudo raspi-config
→ Interface Options → SPI → Enable
Reboot, then check:
ls -l /dev/spidev*
You should see at least:
/dev/spidev0.0
Enable SPI1 (second SPI controller)
SPI1 is not enabled by default.
Edit:
sudo nano /boot/firmware/config.txt
Add one of the following lines (example with 3 chip-selects):
dtoverlay=spi1-3cs
Reboot.
Verify:
ls -l /dev/spidev*
Expected:
/dev/spidev1.0
/dev/spidev1.1
/dev/spidev1.2   (depending on overlay)
If /dev/spidev1.0 does not exist → SPI1 is not active.
Wiring
The node editor shows dynamic wiring instructions depending on SPI0/SPI1 selection.
Typical RC522 pins:
  • 3.3V (⚠️ never 5V)
  • GND
  • SCK
  • MOSI
  • MISO
  • SDA / SS → chip select (CS)
  • RST (optional)
Via Node-RED Palette
Search for:
Manual install
sudo systemctl restart nodered
Node Configuration
Configured entirely inside the node:
  • SPI Bus (0 or 1)
  • Device / CS (0–2)
  • Mode:
    • UID
    • READ
    • WRITE
  • Auto poll + interval
  • Block, Key A, Data, Verify
  • Presence events (present / removed)
  • Removed timeout (ms)
Output Events
Card detected
topic: "present"
payload.event: "present"
Card removed
topic: "removed"
payload.event: "removed"
Read
topic: "read"
payload.data: "<hex>"
Write
topic: "write"
payload.verified: true|false
Safety
To avoid destroying cards:
  • ❌ Block 0 write disabled
  • ❌ Trailer block write disabled (3,7,11,…)
Test / Debug
Check permissions:
groups
# user must be in group: spi
Add user if needed:
sudo usermod -aG spi $USER
Re-login required.
Native build blocked (spi-device / install-scripts warning)
Newer npm versions do not run install scripts until they are approved.
If the install shows npm warn install-scripts ... spi-device, the SPI driver was not compiled (error in Node-RED: Cannot find module ... spi.node).
Fix:
npm install-scripts approve spi-device
npm rebuild spi-device
ls node_modules/spi-device/build/Release/      # must show spi.node
If the rebuild fails with a gyp / make error: sudo apt install build-essential.
MIT
Version: 1.1.6
Updated 3 weeks, 4 days ago
7 in the last week
  • raspi5-rc522
  • node-red-contrib
  • raspberry-pi
  • raspberry-pi-5
  • rc522
  • mfrc522
  • rfid
  • spi
  • spi0
  • spi1
  • mifare
  • mifare-classic
