node-red-contrib-raspi5-neopixel 1.0.0
Raspberry Pi 5 WS2812 / NeoPixel pure JavaScript Node-RED node with SPI0/SPI1, selectable color order (RGB/GRB/...), brightness, per-pixel control and effects
npm install node-red-contrib-raspi5-neopixel
WS2812 / NeoPixel LED strip Node for Raspberry Pi 5 – pure JavaScript, no Python, no external daemon.
Supports:
  • SPI0 and SPI1 (bus/device selectable)
  • Selectable color order (GRB, RGB, BRG, BGR, RBG, GBR) – red is red on every strip model
  • test command to find the right color order in seconds
  • Global brightness (0–100 %) + optional gamma correction
  • Fill, single pixel, range or one color per LED
  • Colors as CSS name, hex, r,g,b, array or object
  • Effects: rainbow, colorcycle, lava, blink, pulse, sparkle, chase
  • Dynamic wiring hints in the Node-RED editor
⚠️ Prerequisite: SPI must be enabled
This node talks directly to /dev/spidev*.
If SPI is not enabled, the node cannot work.
Enable SPI0 (standard)
sudo raspi-config
→ Interface Options → SPI → Enable
Reboot, then check:
ls -l /dev/spidev*
You should see at least:
/dev/spidev0.0
Enable SPI1 (second SPI controller)
SPI1 is not enabled by default.
Edit:
sudo nano /boot/firmware/config.txt
Add one of the following lines:
dtoverlay=spi1-1cs
or (3 chip-selects):
dtoverlay=spi1-3cs
Reboot.
Verify:
ls -l /dev/spidev*
Expected:
/dev/spidev1.0
If /dev/spidev1.0 does not exist → SPI1 is not active.
More than ~170 LEDs
The kernel limits one SPI transfer to 4096 bytes by default (≈ 170 LEDs).
The node shows an error with the exact numbers if your strip is too long.
Fix: add this to the end of the single line in /boot/firmware/cmdline.txt:
spidev.bufsiz=65536
Reboot and check:
cat /sys/module/spidev/parameters/bufsiz
65536 bytes ≈ 2700 LEDs.
Wiring
The node editor shows dynamic wiring instructions depending on SPI0/SPI1 selection.
Only the MOSI pin is used as data line:
Bus MOSI (→ LED DIN)
SPI0 GPIO10 (Pin 19)
SPI1 GPIO20 (Pin 38)
  • GND Pi ↔ GND LED ↔ GND power supply (⚠️ common ground is mandatory)
  • 5V LED from an external power supply (⚠️ never more than a few LEDs from the Pi 5V pin)
  • ~60 mA per LED at full white
  • Recommended: 330 Ω in series with DIN, 1000 µF across 5V/GND at the strip
  • WS2812 expects 5V logic: short data wire (< 30 cm) or a 74AHCT125 / 74HCT245 level shifter
Via Node-RED Palette
Search for:
Manual install
sudo systemctl restart nodered
Node Configuration
Configured entirely inside the node:
  • SPI Bus (0 or 1)
  • Device / CS (0–2)
  • SPI speed (Hz, default 6400000)
  • Number of LEDs
  • Color order: GRB (most WS2812/WS2812B), RGB, BRG, BGR, RBG, GBR
  • Brightness (%)
  • Gamma correction
  • Off on close (LEDs off on deploy / stop)
Finding the right color order
Send:
msg.payload = "test"
  • LED 0 must be red, LED 1 green, LED 2 blue
  • Red and green swapped → switch between GRB and RGB
  • Blue in the wrong place → try the other orders
Input
Fill the whole strip
msg.payload = "red"            // CSS color name (148 names)
msg.payload = "#FF8000"        // hex, also "#F80" or "FF8000"
msg.payload = "255,128,0"      // also "rgb(255,128,0)"
msg.payload = [255, 128, 0]
msg.payload = { r: 255, g: 128, b: 0 }
Single pixel / range
msg.payload = "blue"
msg.pixel   = 4                // only LED 4
msg.payload = "green"
msg.start   = 10
msg.count   = 5                // LEDs 10..14
Other LEDs keep their color.
One color per LED
msg.payload = ["red", [0,255,0], "#0000FF", "off"]
LEDs not in the array are switched off.
Off
msg.payload = "off"            // also "clear" or "black"
Brightness
msg.brightness = 30            // 0..100 %, stays active
Can be sent alone (no payload) or together with a color.
Effects
msg.payload  = "pulse"
msg.color    = "orange"        // optional (blink, pulse, sparkle, chase)
msg.interval = 30              // optional, ms per frame
Effect Description
rainbow moving rainbow over the strip
colorcycle whole strip cycles 7 colors
lava red/orange flicker
blink on/off (msg.color)
pulse smooth fade in/out (msg.color)
sparkle random twinkles (msg.color)
chase one LED running along the strip (msg.color)
An effect runs until the next message.
Output
No output. The node status shows the current state:
  • green dot: ready / color
  • blue dot: effect running
  • yellow dot: test pattern
  • grey ring: off
  • red ring: error
Examples
Menu → Import → Examples → node-red-contrib-raspi5-neopixel → basic
Safety
  • ❌ Never power long strips from the Pi 5V rail
  • ❌ Never hot-plug a strip while powered
  • ✅ Test with low brightness first
Test / Debug
Check permissions:
groups
# user must be in group: spi
Add user if needed:
sudo usermod -aG spi $USER
Re-login required.
Wrong / flickering colors:
  • wrong color order → use test
  • missing common GND or weak power supply
  • long data wire without level shifter
Credits
Based on @tomsith/node-red-contrib-ws2812-pi5 by Tom Schmitz (MIT).
MIT
Version: 1.0.0
Updated 3 weeks, 4 days ago
  • raspi5-neopixel
  • node-red-contrib
  • raspberry-pi
  • raspberry-pi-5
  • neopixel
  • ws2812
  • ws2812b
  • led
  • led-strip
  • addressable
  • spi
  • spi0
  • spi1
