node-red-contrib-raspi5-lcd-16x2 0.1.1
Raspberry Pi 5 HD44780 16x2 LCD via PCF8574 I2C (addr 0x38)
npm install node-red-contrib-raspi5-lcd-16x2
Node-RED node for Raspberry Pi 5 to write text to a 16x2 I²C LCD at address 0x38 (7-bit), using pure JavaScript via i2c-bus.
This targets I²C-controlled LCD modules (often ST7032/AIP31068-like), not PCF8574 backpacks (typically 0x27 / 0x3F).
From the Node-RED user directory:
npm i node-red-contrib-raspi5-lcd-16x2
Restart Node-RED.
Prerequisites (Raspberry Pi)
  1. Enable I²C in the OS.
  2. Ensure your user can access /dev/i2c-1 (group i2c).
Check device address:
sudo i2cdetect -y 1
# you should see "38"
Node usage
Input
Send either:
  • msg.payload as string → written to line 1 (line 2 stays empty)
or
  • msg.payload as object:
{ "line1": "Hello", "line2": "Addr 0x38" }
Config
  • I²C Bus (default 1)
  • Address (default 0x38)
  • Contrast (0-15) (default 8) — if the LCD is blank, try changing this.
Troubleshooting
If i2cdetect shows 38 but nothing appears:
  • Try contrast values 0–15.
  • Verify wiring (SDA/SCL + 3.3V/GND) and pull-ups.
  • Some LCD modules need a slightly different init sequence.
MIT
Version: 0.1.1
Updated 9 months ago
79 in the last week
  • raspi5-lcd-16x2
  • node-red-contrib
  • raspberry-pi
  • raspberry-pi-5
  • i2c
  • lcd
  • 16x2
  • hd44780
  • pcf8574
