node-red-contrib-qwatch 0.0.2
The node accessing for IODATA Qwatch network camera API
npm install node-red-contrib-qwatch
The node accessing for IODATA Qwatch network camera API.
The node tested Qwatch TS-NS110W and TS-WRLP. Because they are devices that main committer (1ft-seabass) is using. :)
Move your Node-RED user directory ~/.node-red
npm i node-red-contrib-qwatch
or
  • Go to "Palette Manager" menu on your Node-RED.
  • Search "node-red-contrib-qwatch" on Node-RED Library.
  • Click "Install".
Prepare node-red-contrib-image-output node
This sample flow need also node-red-contrib-image-output node.
Install it.
Sample flow for snapshot:
[{"id":"89c76fc9.b548e","type":"inject","z":"11cb14b2.1f95cb","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":380,"y":260,"wires":[["e241db8e.be7b88"]]},{"id":"dfe1a4d1.79c808","type":"debug","z":"11cb14b2.1f95cb","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":890,"y":240,"wires":[]},{"id":"e6f0c3e6.91bc7","type":"image","z":"11cb14b2.1f95cb","name":"","width":"480","data":"payload","dataType":"msg","thumbnail":false,"active":true,"pass":false,"outputs":0,"x":900,"y":300,"wires":[]},{"id":"e241db8e.be7b88","type":"qwatch-snapshot","z":"11cb14b2.1f95cb","name":"","setting":"dfac201.f94f3e","x":620,"y":260,"wires":[["dfe1a4d1.79c808","e6f0c3e6.91bc7"]]},{"id":"dfac201.f94f3e","type":"qwatch-config","z":"","name":"Setting1","serveraddress":"192.168.XX.XX","serverport":"XXXXX"}]
Import this flow. This is for getting datas.
This flow will place like this.
Set Qwatch setting
Edit the detail of Qwatch snapshot node.
Edit Qwatch setting named "Setting1".
Set these settings,
  • Server Address
    • Qwatch Server Address
  • Server Port
    • Qwatch Server Port
  • Login ID
    • The ID can login to Qwatch admin page.
  • Login Password
    • The password can login to Qwatch admin page.
Change settings. Deploy this flow after that.
Click inject node
The node will get a current snapshot from Qwatch when you clicked the inject node.
The node will get a current snapshot from Qwatch.
History
  • v0.0.1
    • First release.
MIT License
Version: 0.0.2
Updated 2 years ago
3 in the last week
  • qwatch-config
  • qwatch-snapshot
  • qwatch
