node-red-contrib-qrdecode 0.0.2
node for decoding qr code from an image file
npm install node-red-contrib-qrdecode
A Node-RED node to decode a QR code from an image file.
Run the following command in the root directory of your Node-RED install or home directory (usually ~/.node-red) and will also install needed libraries.
The node takes the full (absolute) path of the image file as an input and then sets the message payload with the decoded content of the QR code contained in the image.
If it does not detect or can not decode the QR code, it returns an error message in the message payload.
This node basically wraps the excellent qrcode-reader node module for decoding the QR code.
Runtime information
This node was tested to Node.js v8.10.0 LTS and NPM 5.6.0 on Node-Red v0.18.4
Typical use of this node will be with node-red-contrib-usbcamera.
Example Flow
Version: 0.0.2
Updated 7 years, 8 months ago
44 in the last week
  • qrdecode
  • qrcode
  • qr-code
