node-red-contrib-qcloud-iotexplorer 1.0.1
Tencent Cloud IOT Node-RED Nodes
npm install node-red-contrib-qcloud-iotexplorer
腾讯云IoT Node-RED 节点
提供了订阅、发布、连接三个节点,在MQTT Broker节点填入三元组(设备ID、设备名称、设备密钥)即可连接腾讯云IoT Explorer,支持多设备发布与订阅
连接Node:Tencent IoT MQTT Broker
创建与腾讯云IoT Explorer的连接,对于同一设备的订阅和发布,可以复用同一连接。
节点属性
  • productID:产品ID
  • deviceName:设备名称
  • deviceSecret:设备密钥
订阅Node:Tencent IoT Subscribe
通过节点连接腾讯云IOT Explorer,订阅topic,输出下发的内容
使用该节点前,需要先选择一个MQTT Broker以建立链接,多个(订阅和发布)节点可共享同一连接
节点属性
  • mqtt broker:必须选择一个MQTT Broker连接
  • topic:订阅主题
输出
输出一个msg对象,包含topic和payload两个属性
  • payload:云端下发的内容,类型为json对象
  • topic:订阅的主题,类型string
使用flow示例
使用Tencent IoT Subscribe节点,连接debug节点,当收到消息时,输出内容到debug面板和控制台。
1627895012037
[{"id":"d30ad81072911a8e","type":"tab","label":"流程 2","disabled":false,"info":""},{"id":"f29a3084b539a50a","type":"iot-mqtt-subscribe","z":"d30ad81072911a8e","name":"Tencent IoT Subscribe","mqttBroker":"4f3add6f82ac43ce","topic":"$thing/down/property/productID/deviceName","x":440,"y":120,"wires":[["e60fc6eebf814f57"]]},{"id":"e60fc6eebf814f57","type":"debug","z":"d30ad81072911a8e","name":"","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":120,"wires":[]},{"id":"4f3add6f82ac43ce","type":"Tencent IoT MQTT Broker","productId":"PANZZ3FT75","deviceName":"dev1","deviceSecret":"deviceSecretx==xxxxxxxxxxxxx"}]
发布Node:Tencent IoT Publish
通过节点连接腾讯云IOT Explorer,向设备publish内容
节点属性
  • topic:publish的主题,优先级小于input
输入
  • payload:上报的内容,类型为json对象
  • topic:publish的主题,类型string。 可以通过input来传递topic,也可以通过设置public结点的属性来指定topic,input的中topic的优先级大于节点属性
例-属性上报,payload需要包含method与params属性
msg.topic = $thing/up/property/${productID}/${deviceName}
msg.payload = {
  // 上报为report
  method: "report",
  // 物模型
  params: {
    key1:"value1",
    key2:"value2"
输出
输出msg对象,包含topic和payload两个属性
使用flow示例
使用inject节点传递数据给Tencent IoT Publish节点,然后向云端上报数据,可在腾讯云IoT Explorer看到上报的结果,上报成功后,将结果向后透传
[{"id":"b104cbb85796c49d","type":"tab","label":"流程 1","disabled":false,"info":""},{"id":"080dbfa3836fa2c4","type":"iot-mqtt-publish","z":"b104cbb85796c49d","name":"Tencent IoT Publish","mqttBroker":"4f3add6f82ac43ce","topic":"$thing/up/property/prodid/dev1","x":470,"y":520,"wires":[["f8229b6f9976186c"]]},{"id":"f8229b6f9976186c","type":"debug","z":"b104cbb85796c49d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":740,"y":520,"wires":[]},{"id":"a9ba14d8e4af9ed2","type":"inject","z":"b104cbb85796c49d","name":"传送上报数据","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"method\":\"report\",\"params\":{\"a\":1}}","payloadType":"json","x":190,"y":600,"wires":[["080dbfa3836fa2c4","413d652b216812d4"]]},{"id":"413d652b216812d4","type":"iot-mqtt-publish","z":"b104cbb85796c49d","name":"Tencent IoT Publish","mqttBroker":"2741096fb5a14003","topic":"$thing/up/property/prodid/dev2","x":450,"y":680,"wires":[["30fe439f6feb1f1e"]]},{"id":"30fe439f6feb1f1e","type":"debug","z":"b104cbb85796c49d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":720,"y":680,"wires":[]},{"id":"4f3add6f82ac43ce","type":"Tencent IoT MQTT Broker","productId":"PANZZ3FT75","deviceName":"dev1","deviceSecret":"WxCCBmkOw0xxxxxxxxx"},{"id":"2741096fb5a14003","type":"Tencent IoT MQTT Broker","productId":"PANZZ3FT75","deviceName":"dev2","deviceSecret":"F4/jzvRc6Jxxxxxxxxxx"}]
Version: 1.0.1
Updated 5 years, 1 month ago
4 in the last week
  • iot-mqtt-subscribe
  • iot-mqtt-publish
  • Tencent IoT MQTT Broker
