node-red-contrib-python-function-ps 0.1.1
Function Node for execute python in Node-RED
npm install node-red-contrib-python-function-ps
Python Function Node-RED Node using python-shell
supported platforms
  • Windows
  • Linux(tested on WSL)
  • OSX(tested on M1)
supported python versions
  • Python 2.7
  • Python 3.x(tested on 3.7 and above)
install via npm or Node-RED palette manager.
npm install node-red-contrib-python-function-ps --save
Like function node, write python code instead javascript code and run.
# user code here.
a = 1234
node.globals["a"] = a
del node.globals["a"]
write_output("a", a)
msg["payload"] = read_input("a")
return msg
Example Flow
[{"id":"382690a637ad27e8","type":"inject","z":"588e7dc76a18c895","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":200,"wires":[["c10a056d2aa1dea0"]]},{"id":"412d6d40234f18ed","type":"debug","z":"588e7dc76a18c895","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":800,"y":200,"wires":[]},{"id":"c10a056d2aa1dea0","type":"python-function-ps","z":"588e7dc76a18c895","name":"","pythonPathType":"global","pythonPath":"python3","globalPythonName":"pythonPath","importPathList":[],"fnCodePre":"\n# user code here.\n\nreturn msg\n","fnCode":"\n# user code here.\n\nmsg[\"T\"] = { \"a\": 1, \"b\": 2 }\n\nreturn msg\n","fnCodePost":"\n# user code here.\n\nreturn msg\n","x":350,"y":200,"wires":[["651e7099d7f27af8"]]},{"id":"651e7099d7f27af8","type":"python-function-ps","z":"588e7dc76a18c895","name":"","pythonPathType":"global","pythonPath":"python3","globalPythonName":"pythonPath","importPathList":[],"fnCodePre":"\n# user code here.\n\nreturn msg\n","fnCode":"\n# user code here.\n\nmsg[\"payload\"] = msg.pop(\"T\")\n\nreturn msg\n","fnCodePost":"\n# user code here.\n\nreturn msg\n","x":590,"y":200,"wires":[["412d6d40234f18ed"]]}]
Todos
[x] Support for 'node.log', 'node.error' functions.
[x] Support 'global' object for python.
[x] Support 'flow' object for python.
[x] Support for 'additional import paths'.
[ ] More intuitive stacktrace.
Version: 0.1.1
Rating: 4.7 6
55 in the last week
  • python-function-ps
  • function
  • python
