node-red-contrib-pushsafer 1.0.3
A PushSafer API wrapper for Node-RED
npm install node-red-contrib-pushsafer
A Pushsafer API wrapper for Node-RED.
Supports rich notifications and notification templates.
Pushsafer logo
Or use the palette manager inside of Node-RED
npm
Required inputs
Optional inputs, if provided they will override the template values
  • msg.title (string): Subject / title of a push-notification, max. 255 characters, see description
  • msg.icon (number): Instead of the default Pushsafer icon, which is displayed with the push notification, you can choose between 177 other icons, see description
  • msg.iconcolor (color): Color of the background of the icon, see description
  • msg.sound (number): Ringtone / Sound which should be played when receiving the push notification, see description
  • msg.vibration (number): How often the device should vibrate when receiving a push-notification, see description
  • msg.priority (number): This priority value determines where the push notification will be put in the notification shade (this sorting affects Android devices only), see description
  • msg.devices (string): This parameter controls to which devices or device groups the message is sent to, see description
  • msg.timetolive (number): Specifies how long a message should be kept in the client APP until it is automatically deleted, see description
  • msg.retry (number): With the retry / resend parameter, a message will be resent after a certain time, see description
  • msg.expire (number): With the retry / resend Parameter re, a message will be resent after a certain time, see description
  • msg.answer (number): To respond to push notifications, pass the parameter with the value 1, see description
  • msg.url (string): This URL can be opened directly from the push notification or from the client-app, see description
  • msg.urltitle (string): Can set the title of the url, see description
  • msg.image (string): The path of an image, which will be shown directly in the notification. Local file path or http(s) url, see description
  • msg.image2 (string): The path of a second image, which will be shown in the Pushsafer app. Local file path or http(s) url, see description
  • msg.image3 (string): The path of a third image, which will be shown in the Pushsafer app. Local file path or http(s) url, see description
Version: 1.0.3
Updated 7 years, 9 months ago
40 in the last week
  • pushsafer-api-key
  • pushsafer-notification-template
  • pushsafer
  • pushsafer
  • notification
  • Smarthome
  • Internet of Things
  • IoT
