node-red-contrib-pulse-edge 1.0.0
Node-RED node for edge detection - outputs pulse on rising/falling edge
npm install node-red-contrib-pulse-edge
A Node-RED node for edge detection - outputs a pulse when a rising or falling edge is detected.
  • Detects rising edge (false→true / 0→1)
  • Detects falling edge (true→false / 1→0)
  • Mode: Rising, Falling, or Both
  • Accepts boolean or 0/1 number input
  • Configurable initial state
  • Single pulse output (no timers needed)
How It Works
Signal:    LOW ──────┐         ┌────── HIGH
Rising:              ↑ PULSE
Falling:                       ↑ PULSE
Both:                ↑ PULSE   ↑ PULSE
Property Description Options
Mode Which edge to detect Rising / Falling / Both
Initial State Assumed state before first input undefined / true / false
Input
  • msg.payload - Boolean (true/false) or Number (1/0)
Output (only on detected edge)
  • msg.payload - Always true
  • msg.edge - "rising" or "falling"
  • msg.previousState - State before the edge
Example Output
  "payload": true,
  "edge": "rising",
  "previousState": false
Examples
Rising Edge Mode
Input: false → (sets state, no output)
Input: true  → OUTPUT {edge: "rising"}
Input: true  → (no change, no output)
Input: false → (falling ignored)
Both Edges Mode
Input: 0 → (sets state, no output)
Input: 1 → OUTPUT {edge: "rising"}
Input: 0 → OUTPUT {edge: "falling"}
Use Cases
  • Button Press: Detect button down (rising) or release (falling)
  • Sensor Trigger: Single action when motion detected
  • Counter: Count each state change
  • Signal Monitoring: Verify signal is still changing (with watchdog)
Node Status
Shows current state and configured mode:
  • HIGH | ↑ - State is true, rising mode
  • LOW | ↓ - State is false, falling mode
  • HIGH | ↑↓ - State is true, both edges mode
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
137 in the last week
  • pulse-edge
  • edge
  • pulse
  • rising
  • falling
  • trigger
