node-red-contrib-ptzoptics 1.0.1
PTZ Camera Control For Node Red
npm install node-red-contrib-ptzoptics
TCP Control for PTZ Optics cameras via Node Red Tested Using the PT20X
Required MSG Object
msg.payload.mode*
The mode to be sent to the camera, look below for supported modes
msg.payload.action*
The action to be sent to the camera under the mode
msg.payload.value*
If the command requires a value these will be passed here as an array of hex. Example: msg.payload.value = [0x01] will select preset 1 if passed to the memory recall function (* = required)
List of Supported Commands
msg.payload.mode = "zoom"
  • msg.payload.action = "stop"
  • msg.payload.action = "teleStandard"
  • msg.payload.action = "wideStandard"
  • msg.payload.action = "teleVariable"
  • msg.payload.action = "wideVariable"
  • msg.payload.action = "direct"*
msg.payload.mode = "focus"
  • msg.payload.action = "farStandard"
  • msg.payload.action = "nearStandard"
  • msg.payload.action = "farVariable"
  • msg.payload.action = "nearVariable"
  • msg.payload.action = "autoFocus"
  • msg.payload.action = "manualFocus"
  • msg.payload.action = "autoManual"
msg.payload.mode = "panTilt"
  • msg.payload.action = "up"*
  • msg.payload.action = "down"*
  • msg.payload.action = "left"*
  • msg.payload.action = "right"*
  • msg.payload.action = "upLeft"*
  • msg.payload.action = "upRight"*
  • msg.payload.action = "downLeft"*
  • msg.payload.action = "downRight"*
  • msg.payload.action = "stop"*
  • msg.payload.action = "absolutePosition"*
  • msg.payload.action = "relativePosition"*
  • msg.payload.action = "home"
msg.payload.mode = "memory"
  • msg.payload.action = "reset"*
  • msg.payload.action = "set"*
  • msg.payload.action = "recall"* (* = requires a msg.payload.value to be passed. Look at the offical documentation)
Example
This will recall memory 1
return {
    "payload": {
        "mode": "memory",
        "action": "recall",
        "value": new Buffer([0])
More Commands Avaliable in The Documentation->
Version: 1.0.1
Updated 7 years, 2 months ago
5 in the last week
  • ptz-network
  • ptz-ptz
  • ptz
  • optics
  • camera
  • PT20X
