node-red-contrib-process-list 0.1.11
List processes/tasks running on node-red server
npm install node-red-contrib-process-list
Simple node to get list of running processes/tasks on server hosting Node-Red. It's based on Process-list module.
Install from PALETTE Manager or run the following command in your NODE-RED user directory typically: ~/.node-red
Use the editor to filter output with search string (value) against specified property (property). Process details are returned in output array when propery's value contains search term, the match is case insensitive. You can specify a search term with msg.tasksearch input property also. property must be selected using the editor. Default is 'name or cmdline'. If at least one of these 2 property's value contains search term the process will be returned in output array. When no process are returned from filter (array with no items), the node outputs an empty string. To get info on a specific process use editor and configure a filter based on property value.
example: filter processes where name or cmdline contains the search term: 'node'. Editor image
returns an array with 6 processes
Editor image
Cascade filters are available when 2 or more nodes are join together.
so lets add second node to filter first node search results. Set value to '/bin/dash' and the property to 'path'.
Editor image
returns only one task from the 6 given before in input
Editor image
Do not self join the node (using link in/out nodes) to avoid memory leaks.
Input
msg.tasksearch string term used to filter processes overwriting value specified in the editor. It is case insensitive. To get all processes do not use this input and leave editor field value empty. If this input is not a string it will be evaluated as an empty string therefore editor field value will be used if not empty otherwise no filters will be applied and all processes will be returned in output.
msg.processlist is array of objects used internally to cascade filter processes. Join together multiple node to apply more filters.
Output
msg.processlist array of objects containing the following properties: pid, name, cmdline, ppid, path, threads, owner, priority, starttime, vmem, pmem, cpu, utime, stime.
msg.processlistJSON JSON array of objects.
Tested on raspbian 10 - 32bit. Should work on all Linux distro and Windows 7 and earlier.
Version: 0.1.11
Updated 6 years, 8 months ago
34 in the last week
  • process-list
  • process
  • task
  • monitor
  • program
