node-red-contrib-process-env 0.2.5
Node-RED node for process.env
npm install node-red-contrib-process-env
Released
Date Version Description
2018-07-02 0.2.0 Add selection function.
2017-09-19 0.1.4 Enabled to specify payload.
Feature
  • Package for Node-RED.
  • Get All ENV.
  • Select and get ENV.
npm install --save node-red-contrib-process-env
Case 1
  • Just put it.
Case 2
Input
Set "payload" to "Into".
msg.env = {
    "lang": "LANG",
    "shell": "SHELL",
    "path": "PATH"
Output
msg.payload = {
    lang: "ja_JP.UTF-8",
    shell: "/bin/bash",
    path: "/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin"
Example Flow
Case 1
Example Flow Case 1
        "id": "e7284760.290928",
        "type": "process-env",
        "z": "3b5b5291.aa56ae",
        "name": "process.env",
        "x": 350,
        "y": 220,
                "a5041749.a6f138"
        "id": "5deef14b.acfb3",
        "type": "inject",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "repeat": "",
        "crontab": "",
        "once": false,
        "x": 180,
        "y": 220,
                "e7284760.290928"
        "id": "a5041749.a6f138",
        "type": "debug",
        "active": true,
        "console": "false",
        "complete": "false",
        "x": 530,
        "y": 220,
Case 2
Example Flow Case 2
        "id": "3cbf45c7.20205a",
        "z": "4fd54dd0.9ec404",
        "into": "payload",
        "x": 438,
        "y": 64,
                "7219f5fd.b41e4c"
        "id": "aae536f7.06c948",
        "type": "inject",
        "name": "Inject",
        "topic": "",
        "payload": "",
        "payloadType": "str",
        "repeat": "",
        "crontab": "",
        "once": false,
        "x": 114,
        "y": 64,
                "72164832.140208"
        "id": "7219f5fd.b41e4c",
        "type": "debug",
        "active": true,
        "console": "false",
        "complete": "true",
        "x": 610,
        "y": 64,
        "id": "72164832.140208",
        "type": "template",
        "name": "set env",
        "field": "env",
        "fieldType": "msg",
        "format": "json",
        "syntax": "mustache",
        "template": "{\n    \"lang\": \"LANG\",\n    \"path\": \"PATH\",\n    \"shell\": \"SHELL\"\n}",
        "output": "json",
        "x": 268,
        "y": 64,
                "3cbf45c7.20205a"
Version: 0.2.5
Updated 9 years, 1 month ago
20 in the last week
  • process-env
  • process
  • env
