node-red-contrib-privatus-analytics 1.0.0
Node-RED nodes for Privatus Analytics: get visitors, top pages and live visitors from the API, and receive signed Privatus Analytics webhooks
npm install node-red-contrib-privatus-analytics
Checking your stats means leaving Node-RED and logging into another dashboard. With these nodes your flows get your visitors, top pages and live visitors from Privatus Analytics on their own. So you can post a daily report to Slack, show numbers on a wall screen or send an alert when something changes.
A webhook node is included too. Privatus Analytics can call your flow when an alert fires, a site goes down or an export is ready. The node checks that the call really came from Privatus Analytics before your flow runs.
What you get
Node What it does
privatus stats Visitors, visits, pageviews, bounce rate, visit time and revenue for a site and a period. It can also compare with the period before.
privatus breakdown The top pages, sources, countries, devices, campaigns or events for a period.
privatus realtime How many people are on the site right now, and the top pages, sources and countries of the last 30 minutes.
privatus webhook Starts a flow when Privatus Analytics sends a webhook. It checks the signature and refuses fake or old calls.
Privatus Analytics counts visits without cookies. These nodes only read your reports through the Privatus Analytics API. They never send visits or events. Visits are counted by the tracking script on your website:
<script defer src="https://privatusstats.com/js/pa.js" data-site="pa_XXXXXXXXXX"></script>
In Node-RED, open the menu, then Manage palette, Install, and search for node-red-contrib-privatus-analytics.
Or run this in your Node-RED folder (usually ~/.node-red) and restart Node-RED:
You need Node-RED 3.0 or later and Node.js 18 or later.
Set up
  1. In Privatus Analytics, open Workspace settings, API tokens and create a token. A token with only the analytics.read permission is enough. You can also limit the token to some sites.
  2. Drop a privatus stats node into a flow and open it.
  3. Next to Account, click the pencil and paste your token. Node-RED keeps it in its credentials file, not in the flow itself, so it is not in exports.
  4. Fill in your Site id. It starts with pa_. You find it in Privatus Analytics under Site settings, Tracking.
Example: post yesterday's numbers every morning
The palette has a ready flow. Open the menu, Import, Examples, node-red-contrib-privatus-analytics, daily-stats-and-alerts.
It does this:
[inject every day at 08:00] -> [privatus stats: yesterday] -> [privatus breakdown: top 5 pages] -> [function] -> [debug]
and the function writes a message like this:
Yesterday: 1204 visitors (+12.1%), 3310 pageviews.
Top pages:
1. / (980 views)
2. /pricing (402 views)
Swap the debug node for a Slack, email, Telegram or Discord node to send it.
Using the nodes
All three API nodes start when a message comes in. The settings in the node are the default, and the message can change them:
Message property Meaning
msg.site A site id, such as pa_7Q2K9XH3AB. One node can serve many sites.
msg.period today, yesterday, 24h, 7d, 14d, 28d, 30d, 90d, mtd, last_month, qtd, last_quarter, ytd, 12mo, last_year, all or custom
msg.from, msg.to Dates like 2026-10-01 for the custom period.
msg.compare previous_period or previous_year adds the earlier numbers and the change in percent.
msg.filters Only count some visits, for example [["country","is","US"],["page","starts_with","/blog"]].
msg.dimension Breakdown only: page, referrer, channel, country, device, utm_campaign, event and more.
msg.limit Breakdown only: how many rows, 1 to 1000. The default is 10.
The result is in msg.payload:
privatus stats
  "period": { "from": "2026-10-25", "to": "2026-10-25" },
  "metrics": {
    "visitors": 1204, "visits": 1390, "pageviews": 3310, "views_per_visit": 2.38,
    "bounce_rate": 41.2, "visit_duration": 52000, "revenue": 0
  "change": { "visitors": 12.1, "pageviews": 8.4 }
bounce_rate is a percent. visit_duration is in milliseconds. revenue is in cents. change is only there when you ask for a comparison.
privatus breakdown gives msg.payload.rows, a list with the top values first. Each row has value (the page, source or country) and share (its percent of the total). Page rows have pageviews and visits. Source and country rows have visitors, visits, pageviews and more.
privatus realtime gives msg.payload.live_visitors (visitors in the last 5 minutes) and top_pages, top_referrers and top_countries for the last 30 minutes.
If a call fails, the node raises an error you can catch with a catch node. msg.statusCode has the HTTP status, for example 401 for a wrong token.
Full details of every number are in the Privatus Analytics API docs.
Webhooks
  1. Drop a privatus webhook node into a flow. Pick a URL path, for example /privatus/webhook. The node shows the full address under the path.
  2. Your Node-RED must be reachable from the internet over HTTPS.
  3. In Privatus Analytics, open Workspace settings, Webhooks, add an endpoint with that address and pick the events you want.
  4. Copy the secret (it starts with whsec_) into the node and deploy.
Each webhook from Privatus Analytics has a Privatus-Signature header like t=1761436800,v1=5f2b.... The node works out an HMAC-SHA256 code from the time, a dot and the exact body, using your secret, and compares it with v1. It also refuses a webhook whose time is more than 5 minutes away from now. That stops someone from sending you an old webhook again. A refused webhook gets status 401 and your flow does not run.
A good webhook gets status 200 right away and sends a message with:
  • msg.payload: the body, with id, event, created_at, workspace_id and data
  • msg.event and msg.topic: the event name, such as alert.triggered or uptime.down
  • msg.delivery: the delivery id. A retry of the same delivery has the same id.
  • msg.headers: the request headers
Privacy
These nodes send your API token and the site, period and filters you choose to https://privatusanalytics.com, and nothing else. They do not track anyone.
Development
From the root of the monorepo:
npm install
npm test -w node-red
npm run validate -w node-red   # the Node-RED Flow Library checks
MIT
Version: 1.0.0
Updated 3 weeks, 5 days ago
  • privatus-config
  • privatus-stats
  • privatus-breakdown
  • privatus-realtime
  • privatus-webhook
  • privatus
  • privatus-analytics
  • analytics
  • web-analytics
  • privacy
  • cookieless
  • webhook
