node-red-contrib-printr 0.2.0
Node-RED nodes for a Printr receipt printer (Epson TM-T88V): tickets, to-do lists, shopping, saved tickets, status
npm install node-red-contrib-printr
Node-RED nodes for a Printr receipt printer (Epson TM-T88V). Printr runs on a Raspberry Pi.
You only configure the address of your Printr and its token. Each node does one thing.
printr config holds the server URL (for example http://raspberrypi:8080) and the token. The token is the PRINTR_TOKEN of the Printr (in /etc/printr.env on a Raspberry Pi).
Node Input (msg.payload) Does
printr print a ticket ({ "blocks": [...] }) or a text prints a ticket
printr to-do a text (one item per line), a list, or { "title", "items" } prints a checklist with the date
printr shopping a text (one item per line) or a list adds items to the shopping list
printr ticket (saved) nothing needed: the name is set in the node, or in msg.preset prints a ticket saved in the Printr
printr status nothing needed reads the state: printer_ready, queued, version
A ticket saved in the Printr is visible to the node only if its owner shared it.
Every node sends its messages on, with msg.printr set to:
  • state: printed, queued, stalled, ok or error. A queued or stalled ticket is not an error: the printer gets it later.
  • message: a short description, also shown under the node;
  • errors: the blocks that failed, for a ticket.
The status node puts the state of the Printr in msg.payload.
Example
examples/printr-tickets.json is a flow with one inject per node. Import it with Menu → Import, then set the URL and the token in its printr config node.
Requirements
  • Node-RED 3 or later, on Node.js 18 or later.
  • A Printr server with a token.
From the Node-RED palette (Manage palette), or in your Node-RED directory:
Development
npm test
The tests cover the payload conversions, the answers of Printr and the requests sent to it, against a fake server. They do not need Node-RED or a printer.
Apache License 2.0, like Printr.
Version: 0.2.0
Updated 1 month ago
  • printr-config
  • printr-print
  • printr-todo
  • printr-shopping
  • printr-preset
  • printr-status
  • printr
  • receipt
  • printer
  • escpos
