node-red-contrib-price-timer 0.1.6
Plan device run times from spot prices with the price-timer node
A Node-RED node that plans and controls your energy consumption based on hourly spot prices. Turn on your devices when the electricity is cheapest!
Key Features
- Price-based Scheduling: Automatically finds the cheapest hours to run your appliances.
- Demand Hours: Specify how many hours your device needs to run per day.
- Price Cap: Set a maximum price you're willing to pay. The device won't run above this price.
- Price Level: If the price stays at or below a level for longer than the requested hours, the device runs for that whole stretch.
- Minimum Run Hours: Ensures your device runs for a minimum number of hours, even if the price is above the cap.
- Flexible Control: Outputs simple on/off commands that can be used with any device control node (e.g., MQTT, Home Assistant, etc.).
- Informative Output: Provides a detailed schedule and cost information for monitoring and logging.
You can install this node directly from the Node-RED Palette Manager.
- Go to
Menu -> Manage palette. - Click on the
Installtab. - Search for
node-red-contrib-price-timer. - Click
install.
Alternatively, you can install it via npm in your Node-RED user directory (typically ~/.node-red):
npm install node-red-contrib-price-timer
Local development
A Docker Compose setup runs Node-RED with this repository mounted live. It is an unauthenticated local sandbox: do not expose the ports on a network, and do not store real home-automation credentials in it. The editor has no password. A credential encryption secret is generated on first start under docker/data/ and is not committed to git.
docker compose up --build
Then open http://localhost:1880. The first start loads a sample flow on the price-timer dev tab. Click the inject node to run price-timer. Ports are bound to 127.0.0.1 only.
Edits to price-timer.js and price-timer.html restart Node-RED automatically. Refresh the editor after a restart so it reloads the node definition. Flows and other runtime data stay in docker/data/. The Node.js inspector listens on 127.0.0.1:9229.
msg.prices can be a numeric array, or an object with a spotprice array. The array covers one 24-hour day at any resolution (24 samples = hourly, 96 samples = every 15 minutes). Hours and Min. hours are durations in hours.
The price-timer node has the following configuration properties:
- Name: A descriptive name for the node in your flow.
- Prices: A 24-hour price series of any length (starting from 00:00). This is typically passed in via
msg.prices. - Topic: The topic for the output message (e.g.,
myhome/heating). A value entered here overridesmsg.topic. Leave empty to usemsg.topic. - Hours: The number of hours you want the connected device to be active (wall-clock hours, independent of sample resolution). Leave empty to use
msg.hours. If both are set, the message value is used. - On-value: The value to send when the device should turn on (e.g.,
on,true,1). Leave empty to usemsg.startValue. If both are set, the message value is used. - Off-value: The value to send when the device should turn off (e.g.,
off,false,0). Leave empty to usemsg.stopValue. If both are set, the message value is used. - Price cap: The maximum price at which the device is allowed to run, in the same unit as the price series. A value entered here overrides
msg.priceCap. Leave empty to usemsg.priceCap, or for no cap if the message omits it. - Price level: If the price stays at or below this level for longer than Hours, the device runs for the whole time it is at or below the level. A value entered here overrides
msg.priceLevel. Leave empty to usemsg.priceLevel, or to only run the cheapest Hours if the message omits it. Same unit as the price series. - Min. hours: The minimum number of hours the device must run, overriding the price cap if necessary. Leave empty to use
msg.minHours. If both are set, the message value is used.
Inputs
The node is triggered by an incoming message. The following properties on the msg object are used:
msg.prices(Array | Object): Required. A 24-hour price series as a numeric array, or{ spotprice: [...] }with that series. Length may be 24 (hourly), 96 (15 minutes), or any other count spanning the same day.msg.hours(Number): Optional. Used when Hours on the node is empty. If both are set, the message value is used.msg.priceCap(Number): Optional. Used when Price cap on the node is empty. Same unit as the price series. A Price cap entered on the node overrides this. If both omit it, there is no cap.msg.priceLevel(Number): Optional. Used when Price level on the node is empty. If the series is at or below this level for longer than the requested hours, every such sample is active. A Price level entered on the node overrides this. If both omit it, the schedule is the cheapest hours only.msg.minHours(Number): Optional. Used when Min. hours on the node is empty. If both are set, the message value is used.msg.topic(String): Optional. Used when Topic on the node is empty. A Topic entered on the node overrides this.msg.startValue(*): Optional. Used when On-value on the node is empty. If both are set, the message value is used.msg.stopValue(*): Optional. Used when Off-value on the node is empty. If both are set, the message value is used.
Outputs
The node has two outputs:
Information Output: The first output sends a message containing detailed information about the schedule, including:
msg.payload.prices: The prices used for calculation.msg.payload.nbrOfHours: The target number of active hours.msg.payload.slots: Indexes into the price series for periods when the device will be active.msg.payload.hoursBelowPriceCap: How many hours of the day are at or below the price cap.msg.payload.priceLevel: The price level used, ornullwhen disabled.msg.payload.hoursBelowPriceLevel: How many hours are at or below the price level, ornullwhen disabled.msg.payload.extended:truewhen the schedule was lengthened to cover the whole stretch at or below the price level.msg.payload.startStop: A detailed schedule with start and end times.
Control Output: The second output sends a message to control your device.
msg.payload: Contains the On-value or Off-value (from the message or the node configuration) depending on the current time and schedule.msg.topic: The topic entered on the node, or from the message when that field is empty.
Example Flow
You can create a simple flow to test the node:
- Use an
Injectnode to trigger the flow periodically (e.g., every hour). - Connect it to a
Functionnode to create amsg.pricesarray covering 24 hours (for example 24 hourly prices, or 96 quarter-hour prices). - Connect the
Functionnode to theprice-timernode. - Configure the
price-timerwith your desired settings (hours, topic, on/off values, etc.). - Connect the second output of the
price-timerto aDebugnode to see the on/off commands, or to anMQTT outnode to control a device.
Author
Niklas Ekström
MIT
