node-red-contrib-prib-functions 0.26.0
Node-RED added node functions.
npm install node-red-contrib-prib-functions
Node-Red nodes for various functions:
  • Data Analysis - statistical metrics that has real time option
  • Matrix
  • Transform
  • Test
  • Load Injector
  • Monitor Flow
  • append
  • Spawn Process
  • Host Available
  • node.js os metrics
  • Levenshtein Distance
Data Analysis
Real time metrics which are recalculated on single of data point and posted in msg.result. Key and value can be selected from msg.payload. Includes lag (seasonal) along with delta(defference). Sending message with topic"@stats" places message with all stats on second port. If realtime metrics then a third port is shown where the message is sent if it is an outlier being outside 3 standard deviations from mean. This can be changed to median and number of deviations.
Data Analysis Realtime Data Analysis Pearson R
A set of data analysis functions that can be run over an array of data
Single value metrics:
  • Autocorrelation
  • Autocovariance
  • Average/Mean
  • Maximum
  • Median
  • Minimum
  • Range
  • Standard Deviation
  • Skewness
  • Sum
  • Variance
Array metrics:
  • Deltas
  • Deltas Normalised
  • difference
  • difference seasonal
  • difference seasonal second order
  • Moving Average Simple (SMA)
  • Moving Average Cumulative (CMA)
  • Moving Average Weighted (WMA)
  • Moving Average Exponential (EMA/EWMA)
  • Normalise
  • Standardization (Z-score Normalization)
Array data
  • distances
  • distance(s) minimum between points
  • distance(s) maximum between points
Data Analysis
example:
Data Analysis Realtime example
Data Analysis Pearson R example
Data Analysis example
logistic regression
Perform logistic regression by setting up model with fit then using the model in other nodes to do prediction probability or class
columnar store
Store data into a columnar store with sql select access
Matrix
Define a matrix and perform various functions
  • Define / Define Empty / Create / Create Like/ clone
  • Add / Add Row to Row / Add to Cell / Add Row / Subtract Cell
  • Multiple / Multiple Cell / Divide Cell / Divide Row
  • Transpose
  • Adjoint
  • Cofactor
  • Complement Minor
  • Identity
  • Inverse
  • Determinant
  • Backward Substitution
  • Forward Elimination
  • Gaussian Elimination
  • Reduced Row EchelonForm
  • Row Echelon Form
  • Nearly Equals / Is Square / Get Cell
  • Sum Row
  • Swap Rows
  • To Array Object
Matrix
Transform
Translates a selected msg property to a target property. Messages generates a message for each row or record.
Transformations:
  • Array to
    • CSV
    • HTML
    • ISO8385
    • Messages
    • xlsx / xlsx object (excel uses xlsx)
  • AVRO to JSON (uses avsc)
  • Buffer to compressed
  • Confluence to JSON
  • Compressed to
    • Buffer
    • String
    • JSON
  • CSV to
    • Array
    • HTML
    • Messages
  • CSVWithHeader to
    • Array
    • HTML
    • JSON
  • Date to
    • is between
    • ISO string
    • locale string
    • range limit
  • ISO8385 to Array
  • ISO8385 to JSON
  • JSON to
    • Array
    • Confluence
    • CSV
    • AVRO (uses avsc)
    • ISO8385
    • Messages
    • String
    • XML (uses fast-xml-parser)
  • Number
    • is between
    • range limit
  • path
    • Basename
    • Dirname
    • Extname
    • Format
    • Is Absolute
    • Join
    • Parse
    • Normalize
    • Resolve
  • snappy compress (uses snappy, must install separately)
  • snappy uncompress (uses snappy, must install separately)
  • String to
    • Append
    • Array By Delimiter
    • At
    • Camelize
    • Capitalize
    • Compressed
    • Char At
    • Char Code At"
    • Code Point At
    • Concat
    • Date
    • Delimiter On Case
    • _ to space
    • _ to space Capitilize
    • Drop square bracket prefix
    • Ends With
    • Float
    • Get Word
    • Integer
    • is Between
    • Lower Case
    • Number
    • Prepend
    • JSON
    • Range Limit
    • Split
    • Starts With
    • Timestamp
    • Title
    • Title Grammatical
    • Trim
    • Trim End
    • Trim Start
    • Upper Case
    • Xml String Encode
  • xlsx / xlsx object to array/JSON (excel uses xlsx)
  • XML to JSON (uses fast-xml-parser)
Note, snappy needs to be installed separately as can have issues with auto install as build binaries.
With xlsx object one can use the function in xlsx against the object in functions node. " Example AVRO with schema
Transform AVRO
For Confluence schema contains a list of schemas in form {"<schema id>",<schema>}
Test
Allows a test case for a message to allow simple testing of nodes. Injects a new message via mouse or message. Message sent to first port which can be consumed by other nodes and returned back to node in a loop. The Test node then checks against detailed expected payload result.
Test
example:
Test example
after run
Test example run
append
Append file(s) to payload. Cached to maximise performance. Require can be used to find file.
append
Test example:
append example
The levenshtein distance between two character strings.
Load Injector
Inject messages for a set period of time with varying think time. Primary purpose is testing and useful for load/stress testing.
Has 3 extra data types
  1. generated id - Unique id for each message
  2. generated data - string text generated using dummy-json
  3. generated json - json generated using dummy-json
Load Injector
Test example:
Load Injector example
Monitor Flow
Add on wire between two flows to see message rates in status line. Rate sampled every second and provides rate last second / 10 seconds / 1 minute / 5 minutes.
Monitor Flow
Test example:
Monitor Flow example
Host Available
Test if host is available sending msg to up or down port so action can be taken. Message only sent on state change or if message is sent which doesn't have topic refreshHostAvailable. This topic forces a check rather than time check which can be set.
Host Available
Test example:
Host Available example
Monitor System
System monitoring metrics
Monitor System
Test example:
Monitor System example
os
The metrics from node.js os
os
Test example:
os example
Spawn Process
Spawn process as per node.js manual with ability to set working directory, environment variables and argument passed to process. STDOUT and STDERR are sent as individual messages. RC port is sent a message on closure. Takes in messages that starts a process with ability to add environment values. Message can be sent to kill the process.
Spawn Process
Test example:
Spawn Process example
Tests
Test/example flow in test/generalTest.json
Version
0.26.0 add columnar store node with sql query capabilty
0.24.0 add in logistic regression
0.23.3 Removes bug in test, more translation
0.23.0 Removes bug in test, more translation
0.22.0 Add autocovariance + autocorealationship to real time data analystics, improves test
0.21.0 Add lag/seasonal to real time data analystics
0.20.3 Add difference + monitor system
0.19.0 Improve load injector, fix bug in test comparing buffers, add compression tranforms
0.18.0 Add matrix node
0.17.0 Add finished wire to load injector
Author
Peter Prib
Version: 0.26.0
Updated 9 months ago
License: GPL-3.0
84 in the last week
  • append
  • Data Analysis
  • Host Available
  • logisticRegression
  • Load Injector
  • matrix
  • Monitor Flow
  • Monitor System
  • os
  • Spawn Process
  • test
  • transform
  • gitlab
  • columnar
  • adjoint
  • append
  • analysis
  • autocorrelation
  • autocovariance
  • average
  • avg
  • AVRO
  • arima
  • ARMIA
  • arvo
  • backward substitution
  • columnar
  • columnar data
  • columnar storage
  • compare
  • Complement Minor
  • compression
  • CMA
  • cumulative
  • Cumulative Moving Average
  • data
  • data analysis
  • decompression
  • deflate
  • delta
  • determinant
  • distance
  • difference
  • seasonal difference
  • second order difference
  • euclidian distance
  • EMA
  • EWMA
  • Exponential Moving Average
  • forward elimination
  • functions
  • gauss jordan
  • Gauss Jordan Inverse
  • gaussian elimination
  • gzip
  • host available
  • host status
  • identity
  • inflate
  • injector
  • inverse
  • inverse matrix
  • Linear Correlation Coefficient
  • levenshtein distance
  • load
  • load injector
  • logistic regression
  • matrix
  • maximum
  • mean
  • memory
  • median
  • minimun
  • model
  • monitor
  • moving
  • Moving Average
  • normalize
  • Pearson Product Moment Correlation
  • PPMC
  • Process
  • range
  • realtime
  • Reduced Row Echelon Form
  • Row Echelon Form
  • sample variance
  • sample stddev
  • Simple Moving Average
  • skew
  • SMA
  • snappy
  • sql
  • standard deviation
  • standardize
  • statistics
  • stddev
  • spawn
  • spawn process
  • system
  • testing
  • test
  • tensor
  • translate
  • transform
  • transpose
  • unzip
  • variance
  • weighted
  • Weighted Moving Average
  • WMA
  • xlsx
  • XLSX
  • xcel
  • xml
  • XML
  • zip
  • Z-score
