node-red-contrib-presidio 0.0.3
Node-RED node for Microsoft Presidio Analysis and Anonymization
npm install node-red-contrib-presidio
node-red-contrib-presidio :package:
This is a subflow for interacting with the Microsoft Presidio Analyzer and Anonymizer services.
Install :zap:
Presidio Setup :gear:
The subflow requires Microsoft Presidio services to be running on the host or a remote server that is reachable by Node-RED. The documentation to install Presidio can be found here, we recommend using the Docker approach as follows:
docker run -d -p 5001:3000 mcr.microsoft.com/presidio-analyzer:latest
docker run -d -p 5002:3000 mcr.microsoft.com/presidio-anonymizer:latest
Once the containers are deployed, use the health check to see that the Presidio services are reachable
  • :information_source: POST localhost:1880/HealthCheck
HealthCheck
  • Health Check response payload:
HealthCheckResponse
Analyzer API :toolbox:
  • :information_source: POST localhost:1880/Presidio
The data payload parameter must be a string and you must define the function to analyze.
Analyzing PIIs :adult: :arrow_right:
  • Setting the payload of the Presidio Analysis injector:
Analysis1
Analysis Result :receipt: :back:
  • Analysis response payload:
Analysis2
Anonymizer API :toolbox:
:warning: Refer to Presidio API documents HERE
The data payload parameter must be a string, you must also define the function to anonymize and which action to use for the PIIs (redact,replace,mask,hash,encrypt).
Hashing PIIs :adult: :receipt: :arrow_right:
  • Setting the payload of the Presidio Anonymization injector: Hash1
Hashing Response :receipt: :back:
  • Hashing response payload:
Hash2
Encrypting PIIs :adult: :receipt: :arrow_right:
  • Setting the payload of the Presidio Anonymization injector: Anonymize1
Encryption Response :receipt: :back:
  • Encryption response payload:
Anonymize2
Decrypting PIIs :receipt: :arrow_right:
  • Setting the payload of the Presidio Anonymization injector: Deanonymize1
Decryption Response :adult: :back:
  • Decryption response payload:
Deanonymize2
Version: 0.0.3
Updated 4 years ago
  • node-red-nodegen
  • privacy
  • analysis
  • anonymization
