node-red-contrib-presence-faker 1.8.11
Simulates home occupancy by intermittently activating and deactivating devices (e.g. lights) at random intervals
npm install node-red-contrib-presence-faker
Presence Faker
Node-RED node to simulate home occupancy by intermittently activating and deactivating devices (e.g. lights) at random intervals.
You can configure a time window during which the node should eject random ON / OFF messages (e.g. 07:00 - 14:30), the duration of ON times (min / max) as well as how many ON times (min / max) should be randomly scheduled.
Example Flow
example
Properties Configuration
Properties can be configured statically using the editor or dynamically by injecting a message with a config object.
Static Configuration
example
Dynamic Configuration
You can overwrite the static configuration at runtime by passing a config object as msg.payload to the presence-faker node. All attributes are optional. minDuration and maxDuration are expressed in seconds.
    "windowBegin": "00:00",
    "windowEnd": "23:59:59",
    "minDuration": 60,
    "maxDuration": 600,
    "minCount": 10,
    "maxCount": 25
If the presence-faker node is currently enabled, this will instantly create a new schedule with the new configuration being applied. Otherwise the changes will take effect as soon as the presence-faker node gets enabled.
Combining presence-faker with suncron
You can combine the presence-faker node with the suncron node in order to dynamically set windowBegin and/or windowEnd based on the position of the sun:
Example
Contributions and Suggestions
... are always welcome! Just file a GitHub issue or pull request!
Version: 1.8.11
Updated 1 year, 11 months ago
Rating: 4.9 9
529 in the last week
  • presence-faker
  • smart home
  • vacation
  • presence
  • lights
  • cron
  • occupation
  • simulator
