node-red-contrib-precise-wakeword 0.2.0
a node-red integration of the precise wakeword listener
npm install node-red-contrib-precise-wakeword
A node-red integration of the mycroft precise wake word engine for Linux.
To install this node either search for it in the Node-RED pallete manager or install it from the Node-RED folder (in most cases ~/.node-red) using either:
to install the module from npm or use:
npm install johanneskropf/node-red-contrib-precise-wakeword
to install it directly from the repository (requires git to be installed).
Prerequisites
This node needs the precise-engine binary installed for it to work. There is two ways to install this:
  • option 1: do a binary install of the precise-engine following the first part of the instructions here. You dont need to pip install the python wrapper as the node directly wraps the binary in its place.
  • option 2: do a source install of the whole mycroft-precise package following the instructions here.
Which option you choose largely depends on which wake-word model you want to run. The engine can only run models that were trained on the same or older version as the engine itself. If you want to train your own models you will most likely have to opt for the source install as this way you can choose the same branch that was used for training.
Basic Usage
To use the node in a first step you will have to create a new configuration. This configuration represents the precise-engine and you will have to enter the absolut path to the engine binary in it. If you choose the binary install this will be .../precise-engine/precise-engine relative to the path that you unpacked the binary in. If you choose the source install it will be .../mycroft-precise/.venv/bin/precise-engine relative to your choosen cloning destination. After adding the configuration you now have to enter the path to a model file in the nodes config ui (this file will have the ending .pb). To start you can download the official hey-mycroft-2 wake-word model .pb and .pb.params file from here. For each model you want to use the precise-engine will always need both the .pb and the .pb.params file in the same path/folder. Once you have both the engine and model files set up you need to feed raw audio buffer chunks to the precise-wake nodes input. To do this use for example one of the multiple microphone nodes available for Node-RED:
This stream of audio needs to be in the following format:
  • 16bit
  • little endian
  • signed-integer
  • 16000hz
  • mono
Once the input has started the precise-engine will take anywhere from 10-30 seconds to start up and than listen for the wake-word. When it detects the wake-word it will send a message to its first output that has several usefull properties:
  "keyword":"hey-mycroft-2",
  "timestamp":1612953501615,
  "score":0.6189599310573979,
  "threshold":0.5
  • keyword: the keyword that was configured
  • timestamp: the time at which the keyword was detected
  • score: the score that the detection had
  • threshold: the configured threshold above which the score has to be to count as an activation
To stop the node stop the stream of raw audio buffers and the node will automatically stop.
Settings
  • Engine: choose a configuration which represents the path to the precise-engine binary
  • Model Path: enter the path to the model file (.pb) you want to use
  • Threshold: adjust the threshold above which a detection occurs. The lower the threshold the higher the sensitivity but also the higher the likelihood of false positives. Adjust to find a balance.
  • Min Above: the minimum number of frames within a window that have to be above the threshold to count as an activation. This value can't be bigger than the window size as otherwise you will never get a positive activation. (if you experience double activations you can increase the min activations to be closer or equal to the window size or increase the window size or both)
  • Window Size: the number of audio frames that are used as a window for the rolling average to look for a positive activation. This parameter works in conjunction with the threshold & the minimum activations number. If you encounter to many false positives even when adjusting the threshold you might want to increase the window size or vice versa.
  • Passthrough: if selected the node will pause further detection after a positive match and start to automatically forward the audio buffers from its input.
  • Input Property: the msg property the node listen on for the audio stream.
  • Output Property: the msg property the node sends the message on a positive match on
  • Control property: the msg property the node listens on for control messages
  • Name: the label to be shown in the editor
Control Messages
The node supports several control messages to control its behaviour at runtime. These messages need to be sent as a string in the configured control property of a input msg object:
  • pause: this will pause detection
  • stop_pause: this will unpause a paused detection
  • forward: this will trigger the node to start forwarding the received audio buffers to its second output
  • stop_forward: this will stop the node from forwarding any audio buffers to its second output
  • listen: this acts as a combination of stop_pause and stop_forward
  • stop: this will force stop the precise-engine (can be used to restart the node if audio input is not stopped)
Other Usefull Information
Training Your Own Model
You can train your own model with a precise source install. be warned this process is quite involved. Here are some links that might help you:
Alternatives
If you are looking for an alternative to quickly use personal wake-words without the training process have a look at node-red-contrib-personal-wake-word. This will give you an easy start but will of course not work as a universal wake-word for differnt speakers and will be less noise resistant as it uses a much more simplistic approach.
Constraints
Precise right now only runs on Linux distributions and on hardware thats at least as fast as the Raspberry Pi 3a+.
Version: 0.2.0
Updated 6 years, 3 months ago
5 in the last week
  • precise-wake
  • precise-wake_config
  • wake-word
  • kws
  • wakeword
  • nodered
