node-red-contrib-powerbi 1.0.4
A PowerBI API interaction node-red module which allows to interact with PowerBI service.
npm install node-red-contrib-powerbi
Introduction
TODO: Give a short introduction of your project. Let this section explain the objectives or the motivation behind this project.
This is the home page of the PowerBI node-red module source code repository and is intended for those contributing to PowerBI node-red module nodes or using bleeding edge builds.
The PowerBI node-red module is the new open-source framework to interact with PowerBI API using the popular node-red IOT application integration system. This module includes nodes to pull information, create and manage PowerBI service data and assets.
Getting Started
To install the PowerBI node-red module you need:
  1. Navigate to the node-red node palette
  2. Search for node-red-contrib-powerbi package
  3. Install the module
All new nodes will appear under a PowerBI category.
Version: 1.0.4
Updated 9 years, 6 months ago
Rating: 3.0 2
17 in the last week
  • powerbi-connection
  • powerbi-groups
  • powerbi-reports
  • powerbi-import
  • powerbi-dataset
  • powerbi-export
  • powerbi-dashboards
  • powerbi-gateways
  • PowerBI
  • API
