node-red-contrib-postgrestor 0.0.5-RC01
Yet another Node-RED node to query PostgreSQL
npm install node-red-contrib-postgrestor
CircleCI NPM version dependencies Status devDependencies Status npm npm npm npm
Node-red-contrib-postgrestor :space_invader: is a Node-RED node allowing basic access to Postgres :elephant: database.
Node-red-contrib-postgrestor sets up a console to execute queries against the configured database.
msg.payload will contain the result object of the query. It has the following properties:
  • command: The sql command that was executed (e.g. "SELECT", "UPDATE", etc.)
  • rowCount: The number of rows affected by the SQL statement
  • oid: The oid returned
  • rows: An array of rows
Postgres implements a template engine allowing parameterized queries:
/* INTEGER id COLUMN */
SELECT * FROM table WHERE id = {{ msg.id }}
/* VARCHAR id COLUMN */
SELECT * FROM table WHERE id = '{{ msg.id }}'
Using the Node-RED Editor
From version 0.15 of Node-RED you can install node-red-contrib-postgrestor directly using the editor. To do this select Manage Palette from the menu (top right), and then select the install tab in the palette.
You can now search for node-red-contrib-postgrestor to install.
Installing npm packaged nodes
To install node-red-contrib-postgrestor npm-packaged node, you can also, either install it locally within your user data directory (by default, $HOME/.node-red):
cd $HOME/.node-red
npm i node-red-contrib-postgrestor
or globally alongside Node-RED:
npm i -g node-red-contrib-postgrestor
You will need to restart Node-RED for it to pick-up node-red-contrib-postgrestor.
NPM
Screen shots
Version: 0.0.5-RC01
Updated 9 years, 1 month ago
License: Apache
Rating: 5.0 2
36 in the last week
  • postgresDB
  • postgrestor
  • postgresql
  • postgres
