node-red-contrib-postgres-variable 0.6.0
PostgreSQL module for Node-RED with dynamic configuration from contexts (flow, global, environment)
npm install node-red-contrib-postgres-variable
Node-RED PostgreSQL Variable Context Module
A Node-RED module for PostgreSQL database operations with support for dynamic configuration from different contexts (flow, global, environment variables).
Edited by Andrii Lototskyi
  • Dynamic Configuration: Get database connection parameters from different contexts:
    • String values (direct input)
    • Flow context variables
    • Global context variables
    • Environment variables
  • SSL Support: Full SSL configuration with certificate validation options
  • Named Parameters: Support for named query parameters using node-postgres-named
  • Connection Pooling: Efficient connection management with PostgreSQL connection pools
  • Error Handling: Comprehensive error handling and reporting
Database Configuration Node
The PostgreSQL database configuration node supports the following parameters, each can be sourced from different contexts:
Connection Parameters
Parameter Description Context Types Default
Host PostgreSQL server hostname str, flow, global, env localhost
Port PostgreSQL server port str, flow, global, env 5432
Database Database name str, flow, global, env -
Username Database username str, flow, global, env -
Password Database password str, flow, global, env -
🔐 Password Security Note: When password type is set to "str" (string), the password is securely stored in Node-RED's credentials system and displayed as a password field (hidden). For other types (flow, global, env), the password reference is stored in the flow configuration for portability.
SSL Parameters
SSL Enable SSL connection bool, flow, global, env false
Ignore SSL Certificate Skip certificate validation bool, flow, global, env false
SSL Certificate Path Path to SSL certificate file str, flow, global, env -
Context Types
  • str: Direct string value
  • flow: Value from flow context (flow.get(key))
  • global: Value from global context (global.get(key))
  • env: Value from environment variable (process.env[key])
  • bool: Boolean value (for SSL options)
Usage Examples
Basic Usage
  1. Configure Database Node:
    • Host: localhost (string)
    • Port: 5432 (string)
    • Database: mydb (string)
    • Username: postgres (string)
    • Password: secret (string)
  2. Use in Flow:
    msg.payload = "SELECT * FROM users WHERE id = $userId";
    msg.queryParameters = { userId: 123 };
Dynamic Configuration from Context
Using Flow Context
// Set in a function node before the postgres node
flow.set("db_host", "production-server");
flow.set("db_name", "prod_database");
Configure database node:
  • Host: db_host (flow context)
  • Database: db_name (flow context)
Using Global Context
global.set("postgres_port", "5433");
global.set("postgres_user", "admin");
  • Port: postgres_port (global context)
  • Username: postgres_user (global context)
Using Environment Variables
Set environment variables:
export DB_HOST=production-server
export DB_PORT=5432
export DB_NAME=production_db
export DB_USER=prod_user
export DB_PASSWORD=secure_password
  • Host: DB_HOST (environment)
  • Port: DB_PORT (environment)
  • Database: DB_NAME (environment)
  • Username: DB_USER (environment)
  • Password: DB_PASSWORD (environment)
SSL Configuration Examples
SSL with Certificate Validation
// Environment variables
export SSL_ENABLED=true
export SSL_CERT_PATH=/path/to/certificate.pem
  • SSL: SSL_ENABLED (environment) → true
  • Ignore SSL Certificate: false (boolean)
  • SSL Certificate Path: SSL_CERT_PATH (environment) → /path/to/certificate.pem
SSL without Certificate Validation
  • SSL: true (boolean)
  • Ignore SSL Certificate: true (boolean)
Dynamic SSL from Flow Context
// In a function node
flow.set("use_ssl", true);
flow.set("ignore_cert", false);
flow.set("cert_path", "/secure/path/cert.pem");
  • SSL: use_ssl (flow context)
  • Ignore SSL Certificate: ignore_cert (flow context)
  • SSL Certificate Path: cert_path (flow context)
Query Examples
Simple Query
msg.payload = "SELECT * FROM users";
Parameterized Query
msg.payload = "SELECT * FROM users WHERE age > $minAge AND city = $userCity";
    minAge: 18,
    userCity: "New York"
Insert with Parameters
msg.payload = "INSERT INTO users (name, email, age) VALUES ($name, $email, $age)";
    email: "[email protected]",
Dynamic Query from Message
msg.payload = "SELECT * FROM " + msg.tableName + " WHERE id = $recordId";
    recordId: msg.payload.id
Custom Connection Configuration
You can also define custom connection configurations in Node-RED settings.js:
module.exports = {
    // ... other settings
    pgConnects: {
        "production": {
            user: "prod_user",
            password: "prod_password",
            host: "prod-server",
            port: 5432,
            database: "production_db",
            ssl: true,
            ignore_check_ssl: false,
            ssl_path: "/path/to/prod-cert.pem"
        "development": {
            user: "dev_user",
            password: "dev_password",
            host: "localhost",
            port: 5432,
            database: "dev_db",
            ssl: false
Use custom connection:
msg.connectName = "production"; // or "development"
Password Security
The module implements intelligent password handling based on the selected type:
String Passwords (Secure Storage)
When password type is set to "str":
  • Password is stored in Node-RED's encrypted credentials system
  • Input field is automatically masked with dots/asterisks (password type)
  • Password is not visible in flow exports
  • Field dynamically switches to hidden mode when "str" type is selected
  • Ideal for static passwords in production environments
Context Passwords (Portable Configuration)
When password type is set to "flow", "global", or "env":
  • Only the reference key is stored in flow configuration
  • Input field shows plain text for easy editing of context keys
  • Actual password value is resolved at runtime from the specified context
  • Flow can be exported/imported without exposing passwords
  • Field automatically switches to text mode for visibility of context references
  • Ideal for dynamic environments and CI/CD deployments
Example Scenarios
Production with Static Password
// Configuration: Password type = "str", value = "mySecretPassword"
// Result: Password stored securely in credentials, not in flow
Development with Environment Variable
// Configuration: Password type = "env", value = "DB_PASSWORD"
// Environment: DB_PASSWORD=dev_password_123
// Result: Password resolved from environment at runtime
Dynamic Password from Global Context
// In a function node:
global.set("current_db_password", "dynamic_password_" + Date.now());
// Configuration: Password type = "global", value = "current_db_password"
// Result: Password resolved from global context at runtime
Error Handling
The module provides comprehensive error handling:
// Errors are sent to the node's error output
// and also attached to the message
if (msg.payload.error) {
    node.warn("Database error: " + msg.payload.error);
    return null; // Stop processing
SSL Configuration Logic
The SSL configuration follows this logic:
  1. SSL = false: No SSL connection
  2. SSL = true + Ignore SSL Certificate = true: SSL connection without certificate validation
  3. SSL = true + Ignore SSL Certificate = false: SSL connection with certificate validation
  4. SSL = true + Ignore SSL Certificate = false + SSL Certificate Path: SSL with custom certificate
Migration from Previous Versions
If you're upgrading from a previous version that used Node-RED credentials:
  1. Username and Password: Now configured through typedInput fields instead of credentials
  2. All Fields: Now support context resolution (flow, global, env)
  3. SSL Configuration: Enhanced with better boolean handling and certificate path options
Dependencies
  • pg: PostgreSQL client for Node.js
  • node-postgres-named: Named parameter support for node-postgres
Apache License 2.0
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
Support
For issues and questions, please use the GitHub issue tracker.
Version: 0.6.0
Updated 8 months, 1 week ago
Rating: 4.6 10
20 in the last week
  • postgresdb
  • postgres
  • postgres
  • postgresql
  • database
  • context
  • environment
  • ssl
  • dynamic-config
