node-red-contrib-post-object-detection 0.1.8
A Node-RED custom node that processes the Object Detection results
npm install node-red-contrib-post-object-detection
This is a custom Node-RED node that handles the prediction results of an Object Detection model.
Prerequisite
This module requires @tensorflow/tfjs-node as a peer dependency. You need to install it within Node-RED manually. TensorFlow.js on Node.js (@tensorflow/tfjs-node or @tensorflow/tfjs-node-gpu), depend on the TensorFlow shared libraries. Putting TensorFlow.js as the dependency of a custom Node-RED node may cause the situation where multiple custom nodes each install their own tfjs-node module as a dependency. This causes an attempt at loading multiple TensorFlow shared libraries in the same process, which subsequently causes the process to abort with a protobuf assertion error.
Therefore, this module puts @tensorflow/tfjs-node as a peer dependency. You need to install it with Node-RED manully.
Install @tensorflow/tfjs-node:
npm install @tensorflow/tfjs-node
This custom Node-RED node leverages the node-canvas npm package to draw the bounding boxes on a image. Please make sure the platform running Node-RED fulfills the prerequisites listed here. For example, while using Ubuntu, you need to run the following command to install the dependencies:
sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
Install this module:
Once you install the peer dependency and the prerequisites, you can install this module:
There are two custom Node-RED nodes in this package:
  • post-object-detection: This is used to process the output of an Object Detection model.
  • bbox-image: This is used to annotate an input original image with bounding boxes.
post-object-detection node
The input for this node should be an array of tf.Tensor objects with a length of 2. The first tensor in this array corresponds to the detected objects with a [1, number of box detectors, number of classes] shape where 1 is the batch size. The second tensor is the bounding boxes with a [1, number of box detectors, 1, 4] shape where 4 is the four coordinates of the box. This node also requires class information through the use of the Class URL property. The file specified here should be a JSON file containing the id and className for each class. For example:
    "0": "person",
    "1": "cup",
The following node properties can also be altered from the defaults:
  • IoU: The intersection over union threshold for determining whether boxes overlap too much with respect to IOU during non-max suppression. Must be between [0, 1]. Defaults to 0.5 (50% box overlap).
  • Min Score: Minimum score needed for a box to be accepted during non-max suppression. Defaults to 0.5.
The node then calculates the object detection results and returns the detected objects as an Object[]. Each object contains bbox, className and score properties.
  • bbox: The coordinates of the box, width and height: [x, y, w, h]. These values are float number between 0.0 and 1.0.
  • className: The name of the class.
  • score: The confidence value between 0.0 and 1.0.
bbox-image node
The msg.payload passed to this node should be an object containing these two properties:
  • image: The image data in Buffer data type
  • objects: An object array containing a list of detected objects. Each object has the following information:
      bbox: [x, y, w, h],
      className: string,
      score: number
This node annotates the image by drawing the bounding boxes of detected objects onto it. This annotated image is then output as a Buffer for the next node.
Version: 0.1.8
Updated 3 years, 7 months ago
47 in the last week
  • bbox-image
  • Object-Detection
  • Bounding-Box
  • Node-RED
