node-red-contrib-polywall-api-v2 1.0.5
Polywall API commands to control videowall
npm install node-red-contrib-polywall-api-v2
This package contains Polywall API nodes to control videowall Contains nodes:
create-source - Node to create sources in Repo or Room.
delete-file - Node to delete file from the room.
delete-reposiotory-file - Node to delete file from the repository.
add-repository-source - Node to put source on a videowall from regular repository.
add-room-source - Node to put source on a videowall from room repository.
refresh-source - Node to reboot already opened source.
start-scenario - Node to start scenario in specified room.
stop-scenario - Node to stop scenario in specified room.
start-scene - Node to start specified scene of running scenario.
close-source - Node to close specified source on a videowall.
clear-display - Node to close all sources on a specified videowall.
move-source - Node to move size or position of the source on a specific value and direction.
toggle-mute-source - Node to switch on/off audio of specified source.
change-source - Node to change settings of specified source.
change-position - Node to change position of a source.
change-size - Node to change size of a source.
next-page - Node to swap page further for sources like pdf, docx, pptx, etc.
previous-page - Node to swap page back for sources like pdf, docx, pptx, etc.
auto-play - Node to start autoplay of sources like pdf, docx, pptx, etc.
room-files - Node to get files from the scenario folder of the specified room.
repository-files - Node to get files from the specified repository.
active-sources - Node to get all active sources in the room.
scenarios - Node to get all scenarios from schedule folder and check which scenario is playing right now.
active-scenes - Node to get all scenes from runing scenario and check which scene is playing right now.
displays - Node to get all displays inside of specified room.
sources - Node to get all active sources in the room (alternative).
list-visualizers - Node to get all active visualizers.
Version: 1.0.5
Updated 6 months, 2 weeks ago
License: GPL-3.0
14 in the last week
  • create-source
  • delete-file
  • delete-repository-file
  • add-repository-source
  • add-room-source
  • refresh-source
  • start-scenario
  • stop-scenario
  • start-scene
  • close-source
  • clear-display
  • move-source
  • toggle-mute-source
  • change-source
  • change-position
  • change-size
  • next-page
  • previous-page
  • auto-play
  • room-files
  • repository-files
  • active-sources
  • scenarios
  • active-scenes
  • displays
  • sources
  • list-visualizers
  • api-config
  • videowall
  • api
