node-red-contrib-polywall-api 0.0.13
Polywall API commands to control videowall
npm install node-red-contrib-polywall-api
This package contains Polywall API nodes to control videowall
Contains nodes:
active-visualizers - The node for getting "Main states" of active visualizers.
list-scenarios - The node for getting list of scenarios.
play-scene - The node turn on the desired scene of the active scenario.
scenario-on - The node turn on the desired scenario.
scenario-stop - The node turn off the scenario.
list-scenes - The node for getting list of scenes.
status-sources - The node for getting status of sources.
mute-source - The node for mute\unmute source.
powerpoint-next - MS PowerPoint source control.
powerpoint-previous - MS PowerPoint source control.
remove-source - The node to delete source from the display.
add-source - The node to add source on the display.
repository-files - The node to get files from the specified repository.
room-files - The node to get files from the scenario folder of the specified room.
shared-server - All Polywall nodes without filled IP address will use IP from this node. Allows to simplify creation of complex flows.
Version: 0.0.13
Updated 2 years, 6 months ago
License: GPL-3.0
Rating: 5.0 3
13 in the last week
  • active-visualizers
  • list-scenarios
  • play-scene
  • scenario-on
  • scenario-stop
  • list-scenes
  • status-sources
  • mute-source
  • powerpoint-next
  • powerpoint-previous
  • remove-source
  • add-source
  • shared-server
  • polywall
  • videowall
  • api
