node-red-contrib-pocketbase 1.0.24
PocketBase node for Node-RED
npm install node-red-contrib-pocketbase
Node-RED PocketBase Integration
Node-RED nodes for PocketBase integration: authentication, CRUD operations, and real-time subscriptions.
npm install
npm run build
  • pb-auth: Authenticate with PocketBase
  • pb-list: List records from collections
  • pb-get: Get a specific record
  • pb-create: Create new records
  • pb-update: Update existing records
  • pb-delete: Delete records
  • pb-realtime: Real-time collection subscriptions
  • pb-download: Download files from PocketBase
Inject → pb-auth → pb-list → Debug
Smart Parameter Resolution
All nodes automatically extract collection and record ID from multiple sources with fallback logic:
// Method 1: Explicit parameters
msg.collection = "users";
msg.recordId = "abc123";
// Method 2: PocketBase record (auto-extracted)
msg.payload = {
  collectionName: "users",
  email: "[email protected]"
// Method 3: Separate record object
msg.record = pbRecord;  // PocketBase record
msg.payload = newData;  // Data for operations
Resolution priority:
  1. Node configuration
  2. msg.collection / msg.recordId
  3. record.collectionName / record.id (auto-extracted)
Chaining benefits:
pb-get → pb-update → pb-delete
Collection and ID automatically propagate through msg.collection and msg.recordId.
File Upload & Download
File Upload (pb-create / pb-update)
Upload files by providing file data in your payload:
// Direct Buffer
msg.payload = {
    name: "My Document",
    file: buffer  // Direct Buffer
// File object with Buffer
msg.payload = {
    file: {
        file: {
            buffer: buffer,           // Buffer data
            name: "document.pdf",     // Filename
            type: "application/pdf"   // MIME type
// File object with URL (auto-downloads)
msg.payload = {
    file: {
        file: {
            url: "https://example.com/file.pdf",
            name: "document.pdf",     // Optional: override filename
            type: "application/pdf"   // Optional: override MIME type
// File object with base64
msg.payload = {
    file: {
        file: {
            base64: "iVBORw0KGgoAAAA...",
            type: "image/png"
// File object with local path
msg.payload = {
    file: {
        file: {
            path: "/path/to/local/file.pdf",
// Multiple files (arrays supported)
msg.payload = {
    photos: [
        buffer1,  // Direct Buffer
        { file: { url: "https://example.com/photo.jpg" } },      // URL
        { file: { base64: "...", name: "photo.png" } },         // base64
        { file: { path: "/local/image.jpg", name: "local.jpg" } } // Local file
Supported formats:
  • Direct: Buffer, File object, ArrayBuffer
  • File object: { file: { buffer/url/base64/path, name?, type? } }
  • Arrays: Mixed arrays of any supported format
File sources:
  • buffer: Direct Buffer or ArrayBuffer data
  • url: HTTP/HTTPS URL (auto-downloaded)
  • base64: Base64 encoded string data
  • path: Local filesystem path (Node.js only)
File Download (pb-download)
Download files from PocketBase records with automatic parameter resolution:
msg.collection = "documents";
msg.filename = "attachment";
msg.mode = "buffer";
// Method 2: Auto-extract from record
msg.payload = {
  collectionName: "documents",
  attachment: "file1.pdf",
  photos: ["img1.jpg", "img2.png"]
// Auto-extracts: collection="documents", recordId="abc123", filename="attachment"
// Method 3: Multiple files with fields
msg.fields = "attachment,photos";  // Download specific file fields
msg.host = "cdn.example.com";     // Override URL host
Download modes:
  • buffer: Returns file content as Node.js Buffer with metadata
  • base64: Returns ready-to-use data URI with MIME type
  • url: Returns only the file URL (no download)
  • url+type: Returns file URL with MIME type (HEAD request only)
Smart filename detection:
  1. msg.filename or node config
  2. record.file (single file field name)
  3. msg.fields (comma-separated multiple fields)
Example flows:
pb-get → pb-download → File Out        # Auto-chaining
pb-list → pb-download → Function       # Batch download
✅ Status
This project is functional and working.
⚠️ Disclaimer
  • Adapt and customize for your needs
  • Author not responsible for issues
  • Test thoroughly before production use
📄 License
MIT License - Open source, modifiable, not for resale.
Version: 1.0.24
Updated 1 year, 3 months ago
465 in the last week
  • pb-auth
  • pb-list
  • pb-get
  • pb-create
  • pb-update
  • pb-delete
  • pb-realtime
  • pb-download
  • pocketbase
  • auth
