node-red-contrib-plugin-notify 0.0.4
Custom notification dialog for Node-RED flow editor
npm install node-red-contrib-plugin-notify
Requires Node-RED 1.3 or later.
Method 1: POST request
When Node-RED instance receives the POST request to 'http://localhost:1880/notify' with JSON data including message and options, Node-RED flow editor will popup the notification dialog.
(1) Simple example
curl command
curl -X POST -H 'Content-Type: application/json' -d '{"message": "Hello"}' http://localhost:1880/notify
Screenshot
(2) Advanced example using options
curl command
curl -X POST -H 'Content-Type: application/json' -d '{"message":"Hello","options":{ "type":"error","timeout":10000,"buttons":[{"text":"OK","class":"primary"}]}}' http://localhost:1880/notify
Screenshot
JSON format to post
    "message": "text",                     // Text which is displayed on the dialog
    "options": {
        "type": "(success|warning|error)", // Style of the message dialog
        "timeout": 5000,                   // Milliseconds until closing the dialog (default: 5000)
        "modal": (true|false),             // Whether user interaction is disabled until closing the dialog (default: false)
        "width": 800,                      // Pixels of the dialog width
        "buttons": [{                      // Array that contains button configurations
            "text": "text",                // Text which is used in the button
            "class": "primary"             // The class of the button (When it is 'primary', the color of the button is red)
Note: If the authentication of the flow editor is enabled, you need to obtain the access token.
Method 2: Timer from starting Node-RED
The configuration should be specified in command-line arguments or the settings.js file.
(1) Command-line arguments example
In this example, the temporary environment will show the message before terminating the environment.
Starting Node-RED with arguments
node-red -D notify.message='This environment will be terminated within 10 minutes. Please download your flow immediately.' -D notify.timer=3000000
Screenshot after 50 minutes
(2) settings.js file example
This example is to show a notification when the Node-RED is updated.
settings.js file
module.exports = {
    notify: {
        message: 'New version of Node-RED is available',
        trigger: function (done) {
            require('request')({ url: 'https://registry.npmjs.org/node-red', json: true }, function (err, res, body) {
                if (!err && body['dist-tags'].latest !== require('./settings').version) {
                    done();
    // the tcp port that the Node-RED web server is listening on
    uiPort: process.env.PORT || 1880,
Screenshot when an update is detected
Install this plugin to Node-RED 1.2
If you want to try this plugin on Node-RED 1.2, you can install it as a node using the old version.
    npm install [email protected]
Version: 0.0.4
Updated 6 years ago
Rating: 5.0 2
60 in the last week
  • notify
  • notification
