node-red-contrib-plugin-header 0.0.2
Custom header UI for Node-RED flow editor
npm install node-red-contrib-plugin-header
Requires Node-RED 1.3 or later.
To open the Node-RED dashboard, this plugin provides button UI on the header area of the Node-RED flow editor.
After the installing this plugin, you can see the dashboard button on the Node-RED flow editor.
Version: 0.0.2
Updated 6 years ago
Rating: 4.0 4
4 in the last week
  • header
