node-red-contrib-plejd 0.0.7
A set of Node-RED nodes for interacting with Plejd
npm install node-red-contrib-plejd
A set of Node-RED nodes for interacting with Plejd.
Run the following command in the user directory of your Node-RED install. This is usually ~/.node-red.
Gathering crypto and device information
Obtaining the crypto key and the device ids is a crucial step to get this running, for this it is required to get the .site json file from the plejd app on android or iOS.
Steps for android:
  1. Turn on USB debugging and connect the phone to a computer.
  2. Extract a backup from the phone:
$ adb backup com.plejd.plejdapp
  1. Unpack the backup:
$ dd if=backup.ab bs=1 skip=24 | python -c "import zlib,sys;sys.stdout.write(zlib.decompress(sys.stdin.read()))" | tar -xv
  1. Recover the .site file:
$ cp apps/com.plejd.plejdapp/f/*/*.site site.json
Steps for iOS:
  1. Open a backup in iBackup viewer.
  2. Select raw files, look for AppDomainGroup-group.com.plejd.consumer.light.
  3. In AppDomainGroup-group.com.plejd.consumer.light/Documents there should be two folders.
  4. The folder that isn't named ".config" contains the .site file.
Gather cryto key and ids for devices
When the site.json file has been recovered the cryptokey and the output addresses can be extracted:
  1. Extract the cryptoKey:
$ cat site.json | jq '.PlejdMesh.CryptoKey' | sed 's/-//g'
  1. Extract the outputAddresses:
$ cat site.json  | jq '.PlejdMesh.outputAdresses' | grep -v '\$type' | jq '.[][]'
Or just open site.json in your favorite editor and extract the crypto key and output addresses (IDs).
connection
All nodes needs to be configured with a Plejd connection. The only setting for the connection is the crypto key.
Input Node
Return state changes of Plejd devices in msg.payload. Example input:
{id: 11, state: 'on', dim: 255}
Output node
Change state of a Plejd device in the mesh by using msg.payload:
{id: 12, state: 'off', dim: 255}
{id: 13, state: 'on', dim: 100}
Thanks
Big thanks to @klali and his https://github.com/klali/ha-plejd component for Home assistant, this project would not have been possible without it.
Version: 0.0.7
Updated 7 years, 7 months ago
7 in the last week
  • plejd
  • plejd out
  • plejd in
  • plejd
  • emilohman
