node-red-contrib-playwright-automation 0.0.4
Node-RED nodes for browser automation with Playwright
npm install node-red-contrib-playwright-automation
Node-RED Playwright Screenshot Node
npm version Downloads License: MIT GitHub issues GitHub stars
A Node-RED node for capturing website screenshots using Playwright. This node provides a simple way to take full-page screenshots of websites directly from your Node-RED flows.
  • High-Quality Screenshots: Capture full-page screenshots in JPEG format
  • Configurable Delay: Wait for dynamic content to load before taking the screenshot
  • Flexible Python Environment: Use system Python or specify a custom Python interpreter
  • Error Handling: Dual output ports for success and error handling
  • Lightweight: Focused on one task - taking screenshots efficiently
Prerequisites
  • Node.js 14 or later
  • Node-RED 2.0 or later
  • Python 3.7 or later
  • Playwright browsers (will be installed automatically)
  1. Install the node in your Node-RED user directory (typically ~/.node-red):
npm install node-red-contrib-playwright-screenshot
  1. Install Playwright and its dependencies:
# Install Playwright
pip install playwright
# Install browser binaries
python -m playwright install
  1. Restart Node-RED
Node Settings
  1. URL to Screenshot (required): The website URL to capture (e.g., https://example.com)
  2. Delay Before Screenshot (optional): Milliseconds to wait after page load before taking the screenshot (default: 1000ms)
  3. Python Path (optional): Path to Python interpreter (default: 'python')
    • Can be a system command (e.g., 'python' or 'python3')
    • Can be a path to a virtual environment (e.g., 'venv/bin/python' or 'venv\Scripts\python.exe')
    • Can be a relative path (resolved from Node-RED's working directory)
Inputs
  • First input: Trigger the screenshot capture
  • msg.url: Override the URL from node configuration
  • msg.screenshotDelay: Override the delay in milliseconds
  • msg.pythonPath: Override the Python path
Outputs
  • First output (success): Contains the screenshot data and page information
      success: true,
      url: 'https://example.com',
      title: 'Example Domain',
      screenshot: 'base64-encoded-jpeg-image'
  • Second output (error): Contains error information if the screenshot fails
      error: 'Error message describing what went wrong'
Example Flow
  1. Inject node → Playwright Screenshot node → Debug node
  2. Configure the Playwright Screenshot node with your desired URL
  3. Connect the first output to a function node to handle the screenshot
  4. Connect the second output to a debug node to catch any errors
Example Function Node to display the screenshot:
// Convert base64 to data URL
msg.payload = {
    topic: `Screenshot of ${msg.payload.url}`,
    payload: `data:image/jpeg;base64,${msg.payload.screenshot}`
Python Environment Setup
For better dependency management, it's recommended to use a Python virtual environment:
  1. Create and activate a virtual environment:
    # Create
    python -m venv venv
    # Activate (Windows)
    .\venv\Scripts\activate
    # Or activate (macOS/Linux)
    # source venv/bin/activate
  2. Install Playwright:
  3. Use the virtual environment in Node-RED:
    • Set the Python Path in the node to your virtual environment's Python executable
    • Example: venv/Scripts/python (Windows) or venv/bin/python (macOS/Linux)
Docker Support
If you're using Docker, the container is pre-configured with Python and virtual environment support. To add Python dependencies:
  1. Add them to requirements.txt in your project root
  2. Rebuild the Docker image
The virtual environment is automatically activated in the container, and all Python scripts will use the isolated environment.
Browser Installation
Playwright requires browser binaries to be installed. You can install them in one of two ways:
  1. Recommended: Add to your requirements.txt:
    playwright
    Then run:
    pip install -r requirements.txt
  2. Or install directly:
This will install the Playwright package and download the required browser binaries.
Troubleshooting
Common Issues
  1. Browser not found
    • Ensure you've run python -m playwright install
    • Check that the Python environment has Playwright installed
  2. Screenshot fails
    • Verify the URL is accessible from the Node-RED server
    • Increase the delay if the page has dynamic content
    • Check the second output for detailed error messages
  3. Python not found
    • Make sure Python is installed and in your system PATH
    • If using a virtual environment, provide the full path to the Python executable
Debugging
  1. Check Node-RED logs for error messages
  2. Enable verbose logging by adding this to your settings.js:
    logging: {
        console: {
            level: "debug"
  3. Test Python manually by running:
    python -c "import playwright; print('Playwright version:', playwright.__version__)"
Development
To contribute to this project:
  1. Fork the repository
  2. Install dependencies:
    npm install
  3. Make your changes
  4. Test your changes
  5. Submit a pull request
MIT - See LICENSE for more information.
Support
For support, please open an issue on GitHub.
Troubleshooting
  • Browser doesn't start:
    • Ensure browsers are installed: python -m playwright install
    • Check if DISPLAY is set for headful mode on Linux
  • Element not found:
    • Verify the page has loaded completely
    • Use page.wait_for_selector() before interacting with elements
  • Timeout errors:
    • Increase timeouts: page.wait_for_selector(..., timeout=10000)
    • Check for iframes that might contain your elements
  • Docker issues:
    • Make sure to install system dependencies in your Dockerfile
    • Use the official Playwright Docker image as a base for easier setup
Example Flows
Basic Navigation Flow
  1. Inject node → Python Function node → Debug node
  2. In Python Function node:
def main(msg):
    from playwright.sync_api import sync_playwright
    with sync_playwright() as p:
        browser = p.chromium.launch(headless=True)
        page = browser.new_page()
        page.goto('https://example.com')
        # Take a screenshot
        screenshot = page.screenshot(type='png')
        browser.close()
        msg.payload = {
            'screenshot': f"data:image/png;base64,{screenshot.decode('latin1')}",
            'timestamp': str(datetime.utcnow())
        return msg
Best Practices
  1. Resource Management:
    • Always close browsers and pages when done
    • Use context managers (with statements) when possible
  2. Error Handling:
    • Wrap browser operations in try/except blocks
    • Implement proper cleanup in finally blocks
  3. Performance:
    • Reuse browser instances when possible
    • Use async/await for concurrent operations
    • Implement proper waiting strategies
  4. Security:
    • Never hardcode credentials
    • Use environment variables for sensitive data
    • Keep Playwright and browsers updated
Acknowledgments
  • Playwright - Reliable end-to-end testing for modern web apps
  • Node-RED - Low-code programming for event-driven applications
Playwright Automation Config
This node configures a Playwright browser instance.
Properties
  • Name: A friendly name for the configuration
  • Browser: Choose between Chromium, Firefox, or WebKit
  • Headless Mode: Run browser in headless mode (default: true)
  • Slow Motion (ms): Slow down execution by specified milliseconds (useful for debugging)
Playwright
This node performs browser automation actions.
  1. Navigate to URL
    • Navigate to a specific URL
    • Can use msg.url or msg.payload as the URL
  2. Click Element
    • Click on an element matching the CSS selector
    • Supports waiting for selectors to be visible
  3. Fill Form
    • Fill a form field with the specified value
  4. Take Screenshot
    • Capture a screenshot of the current page
    • Can save to a file or output as buffer
  5. Evaluate JavaScript
    • Execute JavaScript in the browser context
    • Returns the result in msg.payload
Usage Examples
Basic Navigation
  1. Add a Playwright Automation Config node and configure it
  2. Add a Playwright Automation node and set action to "Navigate to URL"
  3. Connect an inject node and set the payload to a URL (e.g., https://example.com)
  4. Deploy and click the inject node
Form Filling
  2. Add a Playwright Automation node set to "Navigate to URL" with your form URL
  3. Add another Playwright Automation node set to "Fill Form" with the appropriate selector and value
  4. Optionally add a "Click" node to submit the form
  5. Connect them in sequence and deploy
Taking a Screenshot
  1. Add a Playwright Automation node to your flow
  2. In the node configuration:
    • Check "Take Screenshot"
    • Set "Screenshot Delay" in milliseconds (e.g., 2000 for 2 seconds)
  3. Ensure the input message contains a browser property with a Playwright browser instance
  4. Optionally, include a url in the message to navigate before taking the screenshot
  5. The screenshot will be available in msg.screenshot as a base64-encoded data URL
Example message to the node:
    "browser": browserInstance,  // From Playwright browser launch
    "url": "https://example.com",  // Optional: URL to navigate to
    "payload": {
        // Your custom data
Output message will include:
    "screenshot": "data:image/png;base64,...",  // Base64 encoded image
    "screenshotTakenAt": "2025-06-21T10:42:33.123Z",
    "payload": {
        // Your original payload with additional processing
        "processedAt": "2025-06-21T10:42:33.123Z"
Displaying the Screenshot
To display the screenshot in the Node-RED Dashboard:
  1. Add a "ui_template" node from node-red-dashboard
  2. Use the following template to display the image:
<div ng-if="msg.screenshot">
    <h3>Screenshot taken at {{msg.screenshotTakenAt}}</h3>
    <img ng-src="{{msg.screenshot}}" style="max-width: 100%;">
</div>
## Message Properties
### Input
- `msg.url`: URL to navigate to (for "navigate" action)
- `msg.selector`: CSS selector (for "click" and "fill" actions)
- `msg.value`: Value to fill (for "fill" action)
- `msg.payload`: Can be used as URL or value depending on the action
### Output
- `msg.payload`: Contains screenshot buffer (for "screenshot" action) or evaluation result (for "evaluate" action)
- `msg.screenshot`: Alternative property containing screenshot buffer
- `msg.page`: Reference to the Playwright Page object (advanced usage)
## Advanced Usage
### Screenshot Options
- **Take Screenshot**: Enable/disable screenshot functionality
- **Screenshot Delay**: Time to wait (in milliseconds) before taking the screenshot
- **Require Browser Instance**: When enabled, the node will only take screenshots if a browser instance is provided in the message. When disabled, the node will attempt to create a new browser instance if needed.
### Accessing Playwright API
You can access the Playwright Page object directly in function nodes:
```javascript
const page = msg._browserPage; // Available after any Playwright Automation node
// Use any Playwright Page API
const title = await page.title();
msg.payload = { title };
Handling Authentication
// In a function node before navigation
msg._playwrightAuth = {
    username: 'user',
    password: 'pass',
    url: 'https://example.com/login'
Troubleshooting
  • Browser doesn't start: Ensure all dependencies are installed correctly. Try running npx playwright install.
  • Element not found: Make sure you're using the correct selector and the page has loaded completely.
  • Timeout errors: Increase the wait timeout in the node's configuration.
Acknowledgments
Version: 0.0.4
Updated 1 year, 6 months ago
  • playwright-automation-screenshot
  • playwright-automation-pdf
  • playwright
  • browser
  • automation
