node-red-contrib-piwebapi 3.10.0
Node-RED nodes for OSIsoft PI Web API with OMF support and real-time subscriptions
npm install node-red-contrib-piwebapi
Node-RED nodes for OSIsoft PI Web API with OMF support and real-time subscriptions.
Or install via the Node-RED palette manager.
Node Description
PI Web API Config Connection settings (URL, credentials, SSL)
PI Point List List PI Points by name pattern, store in global context
PI Point Read Read current, recorded, interpolated, or plot values
Asset Read Read AF element attribute values
Attribute List List AF element attributes
Write Write values to PI Points (numeric, digital state, system state)
OMF Writer Send OMF type, container, and data messages
Subscribe WebSocket subscription to PI Point value changes
Event Frame Add Create event frames
Event Frame Get Retrieve event frames
Message Serializer Serialize messages for batch processing
Quick Start
Read a PI Point value
[Inject] → [PI Point Read] → [Debug]
Write to a PI Point
[Inject] → [Function: Set Value] → [Write] → [Debug]
OMF workflow (create new stream)
[Inject] → [OMF Type Builder] → [OMF Writer] → [Debug]
[Inject] → [OMF Container Builder] → [OMF Writer] → [Debug]
[Inject] → [Function: Build Data] → [OMF Writer] → [Debug]
PI Web API Configuration
For OMF support, configure these in PI Web API Admin:
Setting Value
CorsMethods GET,OPTIONS,POST,PUT
DisableWrites False
OmfCreateMode Insert
If EnableCSRFDefense is True, the nodes automatically include the X-Requested-With: XMLHttpRequest header.
MIT
Author
Holger Amort
Version: 3.10.0
Updated 8 months, 2 weeks ago
24 in the last week
  • piwebapi-config
  • piwebapi-omf-writer
  • piwebapi-subscribe
  • piwebapi-write
  • piwebapi-pipoint-read
  • piwebapi-asset-read
  • piwebapi-pipoint-list
  • piwebapi-attribute-list
  • piwebapi-msg-serializer
  • piwebapi-eventframe-add
  • piwebapi-eventframe-get
  • osisoft
  • pi
  • piwebapi
  • pi-web-api
  • omf
  • pi-system
  • aveva
  • time-series
  • industrial
