node-red-contrib-pifacecad 0.0.3
A Node-RED node for Raspberry Pi use the PiFace CAD board.
npm install node-red-contrib-pifacecad
About
This module is PiFace CAD node for node red.
Install via Git
Run the following code in your raspberry pi terminal
cd /home/pi/.node-red/node_modules
git clone https://github.com/erfanjahanshahlo/node-red-contrib-pifacecad.git
and restart your node red server or reboot your raspberry pi.
Install via npm
Install via Download
in step one download this repository and rename main folder to node-red-contrib-pifacecad like the schematic below and copy to /home/pi/.node-red/node_modules path in your raspberry pi and restart your node red server or reboot your raspberry pi.
-node-red-pifacecad-lcd
---package.json
---pfc_lcd.py
---pfc_lcd.js
---pfc_lcd.html
---pfc_switch.py
---pfc_switch.js
---pfc_switch.html
Install Dependencies
For install dependencies, in your raspberry pi terminal run the below command.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install python{,3}-pifacecad
Enable SPI
To work with PiFace CAD you must enable the SPI protocol on raspberry pi. To do this you need to execute the following commands in the terminal.
sudo raspi-config
Interfacing Options -> SPI -> Yes
Getting started
To work with lcd node: Here's how to send data to this node.
ROW,COL:YOUR TEXT
for clear lcd send 1,1: to the node to clear lcd.
Be careful not to use any spaces in any of these commands.
Version: 0.0.3
3 in the last week
  • pfc_lcd
  • piface
  • pifacecad
  • nodered
  • node-red-node
  • node_red
  • node-red-node-pifacecad
