node-red-contrib-pi-omxplayer 1.0.1
A Node-RED node to control OMXPlayer on the Raspberry pi
npm install node-red-contrib-pi-omxplayer
This node will accept the following commands as msg.payload:
  • open
  • playpause
  • pause
  • stop
  • volumeup
  • volumedown
  • getduration
  • getposition
  • getstatus
  • getvolume
  • setvolume float (0-1)
  • setposition int
The file to play can be set either in the node configuration or by using msg.filename.
The filename set in the configuration has precedence over msg.filename.
The node will output it's current status periodically in the msg.status object. Calls to the different getter functions will also return a msg.status object.
Version: 1.0.1
Updated 10 years ago
19 in the last week
  • rpi-omxplayer
  • omxplayer
  • raspberrypi
  • raspbian
