node-red-contrib-pi-max31865 0.9.4
A Node-RED node to read from the MAX31865 RTD-to-Digital Converter
npm install node-red-contrib-pi-max31865
node-red-node-pi-max31865
Donate
A Node-RED node to read from the Adafruit MAX31865 board, which can be connected to the PT100 and PT1000 Resistance Temperature Detectors (RTDs).
The node will appear as MAX38165 Converter in the menu, listed in the Raspberry Pi category.
Pre-requisites
  1. Ensure to enable SPI:
  • Run sudo raspi-config
  • Select 5 - Interfacing Options
  • Select P4 - SPI
  • Select yes to enable SPI
  • Select OK to confirm
  • Select the Finish button
  1. Wire the board as described in the Adafruit article for the Python Computer Wiring:
  • Pi 3V3 to sensor VIN
  • Pi GND to sensor GND
  • Pi SPI0 MOSI to sensor SDI
  • Pi SPI0 MISO to sensor SDO
  • Pi SPI0 SCLK to sensor CLK
  • Pi SPI0 CE0 to sensor CS
If you would like to connect multiple MAX31865's to a single Raspberry Pi, have them share the MOSI, MISO and SCLK pins. Then assign the first board the CE0 pin and the second board the CE1 pin.
More details on the Raspberry Pi pinout: https://pinout.xyz/pinout/spi
Find the node MAX38165 Converter in the menu and add it to your workflow. The configuration will lead itself:
  • bus - first digit in /dev/spidev0.0
  • device - second digit in /dev/spidev0.0
  • nominal resistance of sensor
  • reference resistance on board
  • wires used for sensor (2, 3 or 4)
  • name to set a custom name
Connect a debug node to quickly assess that everything is working. The output will appear in the debug panel.
Version: 0.9.4
Updated 7 years, 3 months ago
License: MIT-License
Rating: 1.0 1
6 in the last week
  • pimax31865
  • pi
  • rtd
  • max31865
