node-red-contrib-pi-hole-remote 0.6.1
NodeRed pi-hole Adapter
npm install node-red-contrib-pi-hole-remote
Node RED pi-hole remote
This Node RED module controls a remote pi-hole.
Node-RED is a tool for wiring together hardware devices, APIs and online services in new and interesting ways.
:sparkling_heart: Support my projects
I open-source almost everything I can, and I try to reply to everyone needing help using these projects. Obviously, this takes time. You can integrate and use these projects in your applications for free! You can even change the source code and redistribute (even resell it).
However, if you get some profit from this or just want to encourage me to continue creating stuff, there are few ways you can do it:
  • Starring and sharing the projects you like :rocket:
  • PayPal PayPal— You can make one-time donations via PayPal. I'll probably buy a coffee tea. :tea:
  • ko-fi Ko-fi— I'll buy a tea coffee. :coffee: :wink:
  • Bitcoin—You can send me bitcoins at this address (or scanning the code): 3GqiebqcZeonziRUMYxU35J3jPSMJzpTAc
Thanks! :heart:
:cloud: Installation
First of all install Node-RED
$ sudo npm install -g node-red
Then open the user data directory ~/.node-red and install the package
$ cd ~/.node-red
$ npm install node-red-contrib-pi-hole-remote
Or search for pi-hole-remote in the manage palette menu
Then run
node-red
:yum: How to contribute
git clone https://github.com/naimo84/node-red-contrib-pi-hole-remote.git
cd node-red-contrib-pi-hole-remote
npm install
gulp
npm install /path/to/node-red-contrib-pi-hole-remote
Inputs
  • payload
    • command
      • toggle
      • enable
      • disable
      • status
      • version
    • disabletime number if pihole is disabled, it will be reenabled after disabletime.
    • statustime number After enable/disable/toggle a status is send after statustime (in seconds).
    • pihole string If defined, the config with this name is used. Instead of the config in the properties. If msg.payload.pihole == "all", command will be sent to all configs.
example:
    payload: {
        "command": "toggle",
        "pihole": "pihole #1"
Configuration:
  • URL URL of pi-hole, without http/https and without admin path. (e.g. pihole:8080)
  • Send command to all piholes command wwill to send to all configs
:scroll: The MIT License
Coded with :heart: in :it:
Version: 0.6.1
Updated 5 years, 4 months ago
55 in the last week
  • pi-hole-config
  • pi-hole-control
  • pi-hole
  • Smart Home
  • home automation
  • naimo84
