node-red-contrib-pi-hole 0.0.3
A node to control a local Pi-hole instance
npm install node-red-contrib-pi-hole
Pi-hole node for Node-RED
This node lets you easily interact with a local pi-hole installation.
The pi-hole node is similar to (and based on) the exec node, but lets you more easily interact with Pi-hole running on the same machine as Node-RED.
Supported commands
Most of the pihole command options:
  • Enable
  • Disable
  • Restart
  • Status
  • Stats (the chronometer command)
  • Update
  • Update Gravity
  • Flush logs
  • Get version
  • Search the adlist
  • Logging on/off
  • Whitelist actions/listing
  • Blacklist actions/listing
You may also specify commands/extra parameters through msg.payload input and/or through the custom append option.
TODO
  • Implement the tail command for live output from the Pi-hole log
  • Return json formatted results from Pi-hole, not just stdout.
  • Ability to control remote Pi-hole instances.
Version: 0.0.3
Updated 9 years, 6 months ago
License: See LICENSE in repo
Rating: 1.0 1
6 in the last week
  • pi-hole
  • pi-hole
