node-red-contrib-physical-sandbox 0.1.0
Physical Sandbox for Node-RED: a sidebar pane that shows robots on a real site, moved by MQTT messages and records
Physical Sandbox for Node-RED. A pane in the editor's sidebar shows robots standing on a real site, at real
scale, over a photo or a video of that site. The robots are moved by MQTT messages (ps in) or by a record
(ps play), and what moved can be saved as a record on PS.com.
Requirements: Node-RED 4.1 or later, Node.js 20 or later. Nothing in this version needs Python or psbx, except converting your own URDF (see Robots only this machine has).
In the Node-RED user directory (~/.node-red by default):
npm i node-red-contrib-physical-sandbox
Restart Node-RED. The sidebar gets a tab 「PS」, and the palette gets a category "physical sandbox" with the
nodes ps in and ps play. The plugin never deploys flows and never does anything without a click.
The pane
Open the tab 「PS」 in the sidebar, or press 「別ウィンドウで開く」 (open in a separate window) to put it on another screen. Both show the same scene and the same stream, so you can use either, or both at once.
- Background. Choose a photo or a video of the site. It stays in your browser and in
<userDir>/physical-sandbox/backgrounds/; it is never sent to PS.com. - Floor. Click the four corners of a rectangle on the ground in the picture (1 to 4, going round), enter the lengths of edges 1→2 and 2→3 in metres, and press 「決定」 (Decide). The robots are placed on this floor at real scale.
- Robots. The list is made from three places: the PS.com catalog, the psbx cache
~/.cache/physical-sandbox) and local folders (below). Drag a robot onto the floor to place it. Without a connection to PS.com, only the robots on this computer are listed. - Records. Open one of your own records on PS.com (the list needs a sign-in), a record by
handle/name, or a record file from this computer. Then play, stop or go back to the start (these play the open record again; only opening reads it). The pane shows the site (「現地」) whose messages it takes: opening a record takes the record's site, and 「現地をもとに戻す」 goes back to the plugin's. - Recording the stream. States that arrive through
ps inare kept as a record in the pane, as they come. - Saving. 「上書き保存」 (Save) makes the next version of the record you opened. 「新しい記録として保存」
(Save as a new record) makes a new record under a name you give. Versions are never written over.
「エクスポート」 (Export) writes a record file to
<userDir>/physical-sandbox/exports/. - The agent switch. 「エージェントに映像を渡す」 is off by default and off again after a restart. While it is on, an agent connected through
ps-nodered-mcpcan ask for the pane's pictures (see "Claude Desktop" below).
ps in: from MQTT into the pane
Put ps in after mqtt in (topic ps/#, or narrower). Messages on ps/<site>/<id>/<kind>, with <kind>
one of state, command or event, and a JSON payload with at in milliseconds, move the robots in the pane
and are recorded. The payload may be an object, JSON text or a Buffer, so any Output setting of mqtt in
works; anything else is ignored without an error. The optional Site filter passes only one site. A retained
message moves the robots but is not recorded. The message goes on to the node's output unchanged.
A state is { "at": 1700000000000, "joints": { "shoulder": 0.5 }, "position": [x, y, z], "yaw": 0.2 } with at
least one of joints and position (metres, ROS axes), or for an item
{ "at": …, "type": "item", "parent": "site", "xyz": [x, y, z] }. Only states are kept in a record.
ps play: from a record out to MQTT
ps play plays a record's motion in time as ps/<site>/<id>/state messages, on its output and in the pane.
The record is either JSON pasted into the node or a PS.com record (handle/name or handle/name:version).
Send it start, stop or rewind as the payload, or {"command": "start", "speed": 2, "loop": true}.
Wire its output to mqtt out to publish; retain is mqtt out's setting.
To start music or a video together with it, wire the same inject to the music node as well: both start on the same message.
What ps play plays is not recorded in the pane, and neither are its messages when they come back through a
broker and ps in; they still move the robots.
Your own robot (a URDF) can be shown without sending it anywhere. Convert it with psbx from the main branch (the next release; 0.1.2 on PyPI does not have it yet):
psbx machine bundle path/to/robot.urdf --out ~/robots/myarm --name myarm
and tell Node-RED the folder in settings.js:
physicalSandbox: {
localMachineDirs: ['~/robots'], // folders holding <name>/bundle.json
catalogBase: 'https://physicalsandbox.com', // optional; $PS_CATALOG_URL wins
site: 'local', // optional; the site in ps/<site>/<id>/<kind>
Each robot goes in its own folder under the configured folder (--out is the folder bundle.json is written into). ~ is your home folder, and other relative paths are taken from the user directory. A record that uses such a
robot cannot be saved to PS.com (PS.com does not have the robot); it stays on this computer as 「PS.com 未保存」.
PS.com: sign-in and saving
Press 「PS.com にログイン」 in the pane. It shows a 6-digit code and the address to open (<catalogBase>/vr, which is
https://physicalsandbox.com/vr by default); enter the code there and the pane is signed in. The token is kept in <userDir>/physical-sandbox/ps-com-token.json.
If a save cannot reach PS.com (offline, signed out, PS.com failing), the record is kept in
<userDir>/physical-sandbox/unsent/ and the pane shows 「PS.com 未保存」 with a button 「再送信する」 (Send
again). It survives a restart of Node-RED. If the record you saved over was changed elsewhere meanwhile, your
copy is saved as a new record and the pane says so. A copy that can never go (it uses a robot only this
computer has, or belongs to another account) can be taken away with 「取り除く」 on its line.
Claude Desktop
ps-nodered-mcp lets Claude Desktop (or any MCP client that starts a command) use the agent tools of the Node-RED running on this computer.
Connecting Claude Desktop
Add this to Claude Desktop's configuration (claude_desktop_config.json) and restart it:
{"mcpServers": {"node-red-physical-sandbox": {"command": "npx", "args": ["-y", "-p", "node-red-contrib-physical-sandbox", "ps-nodered-mcp"]}}}
(If the package is installed, "command" can be the path of the ps-nodered-mcp bin instead.) Node-RED must be running with this package installed, and the Node-RED editor open in a browser tab for the tools that need it (flows, pane pictures).
Options (add them to args after ps-nodered-mcp):
--url <address>: the MCP route of Node-RED. Defaulthttp://127.0.0.1:1880/physical-sandbox/mcp; alsoPS_NODERED_URL. When Node-RED's settings sethttpAdminRoot, the address must include it (for examplehttp://127.0.0.1:1880/admin/physical-sandbox/mcpforhttpAdminRoot: '/admin').--user-dir <folder>: Node-RED's user folder (userDir). Default~/.node-red; alsoNODE_RED_USER_DIR. If you start Node-RED with-u <folder>, give the same folder here.PS_BRIDGE_POLL_MS(environment): while Node-RED cannot be reached, how often the bridge looks again for its tools, in milliseconds. Default 5000.
The key lives in <userDir>/physical-sandbox/mcp-key. The plugin creates it when Node-RED starts (readable by your user only; on Windows this file mode has no effect, so the folder's own permissions are what protect it), and the bridge reads it from there. The route answers only this computer, and only with that key.
Limits of "this computer only":
- Behind a reverse proxy or a tunnel on the same computer (nginx, Cloudflare Tunnel, ngrok and so on), every caller looks local to Node-RED, and only the key guards the route. Keep the key file private.
- Node-RED in Docker does not see the host's calls as loopback, so the MCP route refuses them: the bridge does not work with Node-RED in a container.
What the agent can do
- Look at the setup. The status of the pane (sign-in, scene, editors and panes open, the pictures switch) and the robots available, with their joints and chains.
- Work out poses. Inverse kinematics for a chain of a robot (position only in this version): the joint angles that put a hand at a point, or the closest ones when it is out of reach.
- Set the scene and play motion. Place or remove robots, play state messages in the pane (a new attempt replaces the last one; loops can be stopped), and turn messages into a record for a
ps playnode. - Open and save records. Open a PS.com record, and save the stream as a new record or as the next version of the open one (same rules as the pane).
- Work on flows. Read the flows in the open editor and propose a flow (see "No deploying" below). Reading the flows (
ps_flows_read) sends them to the agent, and through it to its AI provider: function nodes' code, broker addresses and the values of environment variables that are not secret (credentials are never included). - Look at the pane. Only while the switch below is on.
The pictures switch
The pane's switch 「エージェントに映像を渡す」 (Share frames with the agent) is off by default and is not kept across restarts: after Node-RED restarts, it is off again. While it is on, the agent can ask for pictures of the pane (ps_pane_frames), and those pictures include the background photo or video. They go to the agent, and through it to the AI provider the agent runs on. This is the one place where pictures leave your machine. They are never sent to PS.com. With the switch off, nothing is sent and the tool is refused.
No deploying
The agent never deploys. ps_flow_propose makes the Node-RED editor import the nodes (in a new tab, with new ids, so nothing of yours is overwritten) as an undeployed change, and shows a notice. Nothing runs until you check it and press Deploy: your Deploy is the approval.
Example
You ask Claude: 「OpenArm に盆踊りさせて」 (make OpenArm dance a bon odori). The agent places OpenArm, works out arm poses with the inverse kinematics tool (both hands above the head, and so on), and plays them in a loop. You see the robot dancing in the pane. Then it may offer a flow: it proposes inject → ps play → mqtt out in a new tab of the editor, waiting for your Deploy. Music is not part of this: sync it with another node. The background (the real site behind the robot) is chosen by you in the pane.
Privacy and limits
- The background photo or video never leaves this computer, except while you turn on the pane's 「エージェントに映像を渡す」 switch: then the pictures go to the connected agent and its AI provider (never to PS.com). Only the record (states and the scene's devices) goes to PS.com, and only when you save.
- When Node-RED's
adminAuthis on, the textures of robots are not loaded (the shapes are).
Development
npm install
npm run build
npm test # against Node-RED 4.1.x
npm run test:nr5 # the smoke test against Node-RED 5.0.x
npm run start:dev # Node-RED on http://127.0.0.1:1881 with this package installed
npm run start:dev -- <userDir> uses that user directory instead of a new temporary one.
