node-red-contrib-petkit 0.2.0
Node-RED nodes for PetKit smart feeders
npm install node-red-contrib-petkit
Node-RED nodes for the PetKit cloud API. Poll feeder status and dispense food from your Node-RED flows. Currently targets the Fresh Element Solo (device type D4) only.
Disclaimer: This project is not affiliated with, endorsed by, or in any way associated with PetKit. It is an independent, community-developed integration created by a happy user of their hardware and software. PetKit and Fresh Element Solo are trademarks of their respective owner. Use of this package is at your own risk. The underlying API is unofficial and reverse-engineered by the community - it may change or break without notice.
petkit-config
Config node. Holds your PetKit account credentials (email, password, region) and manages the session token lifecycle.
Region must match the exact region name shown in the PetKit app's region/country setting (e.g. United States, United Kingdom, Netherlands, China) - getting this wrong fails login with an "unregistered email" error even with correct credentials.
Note: PetKit account passwords are capped at 6-14 characters. A longer password fails login with a generic "incorrect username or password" error indistinguishable from an actually-wrong one - if login fails unexpectedly, check that first.
petkit-feeder
Polls the PetKit cloud API for Fresh Element Solo status. Emits one message per feeder:
Property Type Description
payload.id number PetKit device ID
payload.type string Always d4 for now
payload.name string Feeder name, as set in the PetKit app
payload.serialNumber / payload.firmware string Device serial number and firmware version
payload.desc string PetKit's own human-readable status line, e.g. "Next Dispense: 17:30"
payload.settings object manualLock (child lock), lightMode (indicator light), feedSound (dispense tone), foodWarn (shortage alarm)
payload.state object food (coarse ok/low indicator), batteryPower, batteryStatus, desiccantLeftDays, feeding (1 while actively dispensing)
Send any message to the input to trigger an immediate poll. Set Poll interval to 0 to disable automatic polling (minimum 60s otherwise, per the PetKit API's rate limit).
petkit-feeder-control
Dispenses food from, or changes a setting on, a feeder.
Feed amount Meaning
10, 20, 30, 40, 50 The only portion sizes the D4 accepts
Both deviceId and amount can be overridden per message via msg.payload. If msg.payload.settingKey is set instead, the node updates that setting (e.g. manualLock, lightMode, feedSound, foodWarn) rather than feeding.
msg.payload.skipFeedTime skips one of today's scheduled meals, and msg.payload.restoreFeedTime undoes that skip. Both take seconds since midnight (24300) or "HH:MM" ("06:45") and only affect today. Use a skip before feeding early, so the scheduled meal doesn't dispense a second time.
Examples
  • feed-on-arrival.json in node-red-contrib-surepetcare's examples/ directory - dispenses each cat's meal via petkit-feeder-control, triggered by arrival through the flap (surepetcare-pets). Lives there rather than here since it needs both packages installed either way - see its info panel for the full design.
Reliability
Every API call - polling, feeding, or settings - automatically retries on PetKit's server-busy errors and network errors with exponential backoff before giving up. Session expiry triggers a single automatic re-authentication and retry.
  1. Add a petkit-feeder and/or petkit-feeder-control node to your flow
  2. Create a new PetKit config node with your account email, password, and region
References
Version: 0.2.0
Updated 1 month, 1 week ago
29 in the last week
  • petkit-config
  • petkit-feeder
  • petkit-feeder-control
  • petkit
  • feeder
  • pet
