node-red-contrib-persistent-global-context 1.0.5
Writes all data stored in Global Context to local filesystem to keep program data between Node-Red instance deployments and restarts.
npm install node-red-contrib-persistent-global-context
A Node-RED Node that writes all data stored in Global Context to local filesystem to keep program data between Node-Red instance deployments and restarts.
  • This node will save the Global Context data into a local file when it receives input.
  • So user must define the frequency of local data storage by adjusting the frequency of trigger sent to the node.
  • Use output message to check if the local context file is intact.
Example Flow
[{"id":"062d6b7526c1c316","type":"persistent-global-context","z":"2d2bad85f9c458c5","x":510,"y":280, "wires":[]},{"id":"01d5b21fa1056c7e","type":"inject","z":"2d2bad85f9c458c5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}], "repeat":"0.1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":250,"y":280,"wires":[["062d6b7526c1c316"]]}]
Version: 1.0.5
Updated 3 years, 7 months ago
Rating: 2.0 1
13 in the last week
  • persistent-global-context
  • persistent global context
  • context
  • local context storage
