node-red-contrib-periph-power 1.5.2
Node-RED nodes for power monitor chips
Node-RED nodes for power monitor chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-power.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-power
| Node | Kind | Description |
ade7953-device |
config | Bus configuration for an ADE7953 |
ade7953 |
input | Reads bus voltage, load current, active power, and accumulated active energy from an ADE7953 single-phase multifunction metering IC. |
axp2101-device |
config | I²C bus and address for an AXP2101 |
axp2101 |
input | Reads battery, charger and power-input state from an AXP2101 single-cell power-management IC over I²C. |
ina219-device |
config | I²C bus and address for an INA219 |
ina219 |
input | Reads voltage, current, power, and shunt voltage from an INA219 power monitor over I²C. |
ina226-device |
config | I²C bus and address for an INA226 |
ina226 |
input | Reads voltage, current, power, and shunt voltage from an INA226 power monitor over I²C. |
ina260-device |
config | I²C bus and address for an INA260 |
ina260 |
input | Reads bus voltage, current, and power from an INA260 power monitor (integrated 2 mΩ shunt) over I²C. |
ina3221-device |
config | I²C bus and address for an INA3221 |
ina3221 |
input | Reads bus voltage, shunt voltage, current, and power from an INA3221 three-channel power monitor over I²C. |
lc709203f-device |
config | I²C bus and address for a LC709203F |
lc709203f |
input | Reads cell voltage, state of charge and temperature from an LC709203F 1-cell Li-ion fuel gauge over I²C. |
lm25066-device |
config | I²C bus and address for a LM25066 |
lm25066 |
input | Reads input and output voltage, input current, input power and MOSFET temperature from an LM25066 hot-swap controller over I²C/PMBus. |
ltc4151-device |
config | I²C bus and address for a LTC4151 |
ltc4151 |
input | Reads supply voltage, load current and power from an LTC4151 7–80 V high-side power monitor over I²C. |
max17048-device |
config | I²C bus and address for a MAX17048 |
max17048 |
input | Reads cell voltage and state of charge from a MAX17048 (1-cell) or MAX17049 (2-cell) lithium fuel gauge over I²C. |
