node-red-contrib-periph-motor 1.5.2
Node-RED nodes for motor driver chips
Node-RED nodes for motor driver chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-motor.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-motor
| Node | Kind | Description |
drv2605-device |
config | Bus configuration for a DRV2605 |
drv2605 |
input | Plays haptic effects on an ERM or LRA vibration motor through a DRV2605 haptic driver over I²C (fixed address 0x5A). The EN pin must be high. |
drv8830-device |
config | I²C bus and address for a DRV8830 |
drv8830 |
input | Drives a brushed DC motor through a DRV8830 low-voltage H-bridge over I²C, and reports its fault status. The chip regulates the commanded voltage across the motor, so speed stays constant as the supply sags. |
tmc2130-device |
config | Bus configuration for a TMC2130 |
tmc2130 |
input | Drives a two-phase bipolar stepper motor through a Trinamic TMC2130 over SPI (Mode 3). The chip has no internal step generator, so the node pulses the STEP and DIR GPIOs; moves are blocking. |
tmc2208-device |
config | Bus configuration for a TMC2208 |
tmc2208 |
input | Drives a two-phase bipolar stepper motor through a Trinamic TMC2202 / TMC2208 / TMC2224 over its single-wire UART. The chip's internal step generator moves the motor, so no STEP pulses are needed. |
tmc2209-device |
config | I²C bus and address for a TMC2209 |
tmc2209 |
input | Drives a two-phase bipolar stepper motor through a Trinamic TMC2209 over its single-wire UART. The chip's internal step generator moves the motor, so no STEP pulses are needed. |
tmc5160-device |
config | I²C bus and address for a TMC5160 |
tmc5160 |
input | Drives a two-phase bipolar stepper motor through a Trinamic TMC5160 over SPI (Mode 3) or single-wire UART. The chip's internal SixPoint ramp generator moves the motor; positions are in full steps, speeds in full steps/s and accelerations in full steps/s². |
